hisense 55K321UW help please
  • rotorwayrichard
    • Mar 2023
    • 6
    • South Africa
    Hi Guys , i am asking for help with my set please , agents say that no parts are available as it has been discontinued now for a while , the set is just over 6 years old
    i will cut to the chase , basically it has RSAG7.820 6135 type main board , 6106 type powersupply and 6137 type t-con board , the standby light is on , psuh the power button and nothing happens , if i disconnect the power supply and hold the power button for 30 seconds etc etc , sometimes it power on right up and will work perfectly again until i switch it off back to standby
    I would really appreciate your help in trying to get it working again and on where to start testing and diagnosing possible failure points
    There is no signs on burning on any of the boards and no signs of bulging caps etc etc , i would like to know what the standby voltage should be as some say it is 3 odd v and others say around 5 v !!
    if anyone has the actual figures and test values and could forward them to me please or post them please i would be most grareful
    Secondly , from sets around 6 years ago to sets around 2 years ago , did the screen types change , for example , mine is supposedly a 4k UHD screen , would a screen from say a 55U6G 55 inch hisense be different to mine ?? , the reason i ask is that if it would or could work , i may be able to get a broken screen hisnese with all the internal bits still functioning 100% , could i transfer the guts of the newer model into the chassis and connect to my screen ??? , could that be a possibility should i not be able to get my set to work again....
    Thanks guys in advance and i hope to hear from someone soon with a starting point
    cheers from rainy south africa
  • frannyjunk
    Hisense 40H4F no backlight but turns off after splash screen
    by frannyjunk
    So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
    TIA.
    09-24-2025, 10:59 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Runlinc
    Hisense 55E76GQTUK screen removal?
    by Runlinc
    Hi all, I need to change the backlights in a Hisense 55E76GQTUK. The screen is glued to the chassis, what is the easiest way of delaminating the screen from the chassis please?
    also what double sided tape would you recommend to glue it back in? ….. or is that a question to ask once the screen is out in one piece?
    Many thanks for any ideas you have.
    04-09-2024, 10:02 AM
