Hisense 50P6
  • lotas
    • Jan 2016
    • 4885
    • Russia
    #61
    Re: Hisense 50P6
    Originally posted by viewerau
    When I right click the file,(my link) it will only allow these options
    Preview
    Download
    Copy to
    Details
    If I select Copy to...I can't seem to save it
    If I download it, it turns into this zip folder
    If I extract then, it just comes back with all those folders again.
    My apology for not understanding how to simply grab that one file
    HELP....
    Rename it (extension .rar to .pkg) to get the file : usb_AA6501U.pkg
    • viewerau
      • May 2020
      • 315
      Re: Hisense 50P6
      How bout, left click hold, drag and drop, send to should also work.
      No go either...can any of you access the file via the link I sent, or doesn't the link work for you guys?
      Signature:Seemingly hopeless tv fixer
      • lotas
        • Jan 2016
        • 4885
        • Russia
        #63
        Re: Hisense 50P6
        It's just that your computer perceives files with the pkg extension as rar (you installed, checked the box so that these files can only be opened by the rar archiver).
        If you need to quickly do this, then try on another computer.
        • nomoresonys
          • 12331
          • U.S.
          #64
          Re: Hisense 50P6
          Try Lotus solution, if still stuck maybe this, scroll down to manual update section: https://knowtechie.com/how-to-update...e-tv-software/
          • viewerau
            • May 2020
            • 315
            Re: Hisense 50P6
            manual update.......cannot do that nomoresonys as the tv is stuck with the lines on it, and I cannot see the menus.
            I have uninstalled all my rar, onezip, etc apps...still won't let me move the file anywhere
            • nomoresonys
              • 12331
              • U.S.
              #66
              Re: Hisense 50P6
              Another tutorial there, he talks a lot but does go into detail, might help: https://www.youtube.com/watch?v=KjGDubuxhaY
              • nomoresonys
                • 12331
                • U.S.
                #67
                Re: Hisense 50P6
                I think you are looking at the auto update part, the manual part is way down the list there but doesn't go into great detail.
                • viewerau
                  • May 2020
                  • 315
                  Re: Hisense 50P6
                  I uninstalled all my apps that do zips, rars etc, and then downloaded it, and it saved as the file.
                  Hopefully this looks right?
                  • nomoresonys
                    • 12331
                    • U.S.
                    #69
                    Re: Hisense 50P6
                    Ok, so is that the first file after you extract? then you should be able to move that file to your usb drive, right?
                    • viewerau
                      • May 2020
                      • 315
                      Re: Hisense 50P6
                      It is the third file from the Hisense link.
                      Putting onto usb now
                      • lotas
                        • Jan 2016
                        • 4885
                        • Russia
                        #71
                        Re: Hisense 50P6
                        Yes, you need to transfer this file to a formatted usb stick.
                        • viewerau
                          • May 2020
                          • 315
                          Re: Hisense 50P6
                          Back to square one again.
                          The usb simply seems to be doing nothing.
                          I keep power unplugged, and drain the power by either holding down the tv or remote power button for 60 seconds.
                          I then keep holding the power button and plug in the power, holding, awaiting device notification or boot, but that never arrives.
                          I did also change the file name to upgrade_loader.pkg....no difference.
                          Tried either usb port...ditto
                          My luck with repairs is abysmal.
                          Are we at the end of any help now?
                          Thanks all.
                          • Diah
                            • Feb 2013
                            • 6599
                            Re: Hisense 50P6
                            my post#52 read it again.. your problem at PC
                            1- you need to active at Folder Option to show known extension file .. so you can see the last extension to avoid it written .pkg.pkg
                            2- rename the file to upgrade_loader.pkg
                            • Diah
                              • Feb 2013
                              • 6599
                              Re: Hisense 50P6
                              BTW: yours link of firmware in post#55 its belong only to yours e.mail to download... no other third party can download it.
                              • viewerau
                                • May 2020
                                • 315
                                Re: Hisense 50P6
                                Originally posted by Diah
                                1- usb formatted as FAT32 MBR mode
                                2- the first file with format .pkg dont extract it. just copy it on the stick
                                3- you may need to rename the file upgrade_loader.pkg in case didnt start
                                4- no need 60 second. as son you press power on RC and keep press plug the tv in wall
                                5-insert the USB at USB Ver2 ( black socket at the side of the TV
                                Thanks Diah,
                                I am certain that this is what I have done.
                                I did not realise that you could not see the file, but it is as before, posted here again, and is file number 3
                                I did it all again
                                No change
                                I d/l it and it shows as usb_AA6501U.pkg
                                I transfer the file onto formatted FAT 32 stick
                                I plugged it to tv and it would not boot.
                                I removed usb, changed file name to
                                upgrade_loader.pkg
                                Reinsert to tv
                                All no go still
                                I do not know what/how to format is as FAT32 MBR mode
                                I look in google via search, and it says ....
                                "The first is to simply format the drive using the MBR format. This can be done in Windows by right-clicking on the drive in My Computer and selecting Format. In the Format dialog box, select the option to format the drive for MBR."
                                When I do this I only have the options
                                NTFS
                                FAT32 (default)
                                exFAT
                                In disk management it shows my usb as D 14.32GB FAT32 Healthy Primary Partition
                                It shows no errors.
                                Am I doing this right?
                                THANK YOU
                                EDIT...file ext only shows .pkg the once.
                                • Diah
                                  • Feb 2013
                                  • 6599
                                  Re: Hisense 50P6
                                  Thanks Diah,
                                  if you have srick smaller than 32Gb will be fine.. however to make MBR mode
                                  open CMD on yours PC
                                  write
                                  Code:
                                  1- diskpart  press inter disk part will start
                                  2- list disk  it will show you all disk on PC be sure to choice yours usb stick for example if it under disk 1
                                  3- select disk 1
                                  4- clean
                                  5- convert mbr
                                  6- create partition primary
                                  7- active
                                  8- list partition
                                  9- select partition 1
                                  10- format fs=fat32 quick
                                  11- assign
                                  12- exit
                                  13- exit
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    #77
                                    Re: Hisense 50P6
                                    Maybe that usb drive doesn't want to play nice with your tv, try a different one, you have any less than 8gb?
                                    • viewerau
                                      • May 2020
                                      • 315
                                      Re: Hisense 50P6
                                      Thanks again for the suggestions...I will dig out a small GB USB stick and try again
                                      • viewerau
                                        • May 2020
                                        • 315
                                        Re: Hisense 50P6
                                        lotas, Diah,nomoresonys...
                                        I followed Diah instructions exactly, thanks for the very clear instructions.
                                        I used a 4GB usb stick this time.
                                        Loaded it with the file, changed it's name to upgrade_loader.pkg
                                        Inserted it to Hisense usb port, press power on remote, await boot to let go of power button
                                        Unfortunately it still does as it did before, going straight into the coloured vertical lines, with nothing thereafter.
                                        Tried a number of times, as well as trying in both of the Hisense usb ports.
                                        Gosh, it seems so simple a thing to do, but this Hisense is simply not behaving for us.
                                        Anything else we can try do you think?
                                        Thank you everyone.
                                        • Diah
                                          • Feb 2013
                                          • 6599
                                          Re: Hisense 50P6
                                          Thank you everyone.
                                          my post #21
                                          replace MB
                                          • Prott
                                            [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                            by Prott
                                            Hello dear badcappers!
                                            The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                            Backstory:
                                            After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                            If there is a way to narrow down which memory module is faulty it would make my life much...
                                            06-03-2024, 12:05 PM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • Diah
                                            Hisense 2020 ULED 55U8QF Little Factory Fault end with Big damage !!
                                            by Diah
                                            this set delivered today to my home to inspect and write report to company sold this set 2 weeks before and the customer reject it as it had fault at picture. its look the transport damage happened during the customer sending it back to the company or on the way to me.. who care its not may fault. LOL
                                            this ULED had full array LED backlight. from first look after remove the back cover with dozens of screws as 2 part cover. i found the ribbon cable at the panel side they was not correct fitting in place ( see photos before take the T-CON driver boards & After.) my wounder which...
                                            11-14-2020, 01:43 PM
                                          • tomketcz
                                            schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                                            by tomketcz
                                            Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                                            10-01-2025, 03:13 AM
