LG 37LC02R screen go nuts temporary
  • PowerAmpFreak
    • 982
    • Sweden
    A friend of mine has a LG LCD-TV model 37LC02R which may work properly for months but occasionally the screen goes all weird flashing on and off fast.
    The sound is all present.
    Would this be an indication of screen failure or perhaps inverter problem?
    Any advice is appreciated. He also mentioned I could buy it in this state, but don't know if this is repairable or not.
  • PlainBill
    • Feb 2009
    • 7034
    Re: LG 37LC02R screen go nuts temporary
    I'd be cautious too. A lot depends on the exact nature of the symptoms.
    Possible scenario 1: Usually when the back of the TV is off there are a few points where you can see the backlights 'leaking' through openings in the LCD panel assembly. If the backlights are flashing on and off, that is probably an inverter problem. Probing the BL_ON and Bright pins would be useful. IF both lines are stable, this is an inverter problem, and should be fixable.
    Possible scenario 2: The backlights stay on steadily, the screen alternates between white and a normal picture. This may be a T-con failure, or a problem with the panel itself.
    Possible scenario 3: The backlights stay on normally, the screen alternates between a normal picture and static. This is most likely a problem with the main board.
    I don't know how much your time is worth (mine's dirt cheap), but diagnosing intermittent problems like this can be very time consuming. Obviously, if you open it up, find and replace a number of bulging caps, and reseat all cables, then it works perfectly, you should be happy. Even replacing the T-con or inverter and getting a working TV could be profitable. But spending 20 hours on it without identifying the failing part would not be profitable.
    PlainBill
    • PowerAmpFreak
      • 982
      • Sweden
      Great input, Bill. I decided to keep my fingers away from this one.
      Those intermittents are often very very time consuming, like you say...
      Better stay away.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
