LG 42LN5400 - restarts every 10 sec
  • nomoresonys
    • 12328
    • U.S.
    Re: LG 42LN5400 - restarts every 10 sec
    Originally posted by Diah
    there are nothing wrong with TV... its the source problem.
    however LG Tv had command IN_STOP.. this will repair and make hard reset to the LG .. in case there are fault at TV
    This is my thought too, source problem.
    • lotas
      • Jan 2016
      • 4852
      • Russia
      And it seems to me more that the problem is in the Nand firmware.
      • YellowJacket
        • Dec 2020
        • 107
        • Slovakia
        Hi lotas. Anything I can do with this? I have only TL866II PLUS programmer, not sure if it can handle it.
        • lotas
          • Jan 2016
          • 4852
          • Russia
          Have you ever read and written Nand Flash? As for your programmer, see if it supports your Nand, which is on the board of your TV.
          • YellowJacket
            • Dec 2020
            • 107
            • Slovakia
            No, I haven't written any so far, but I believe, I would be able to do it. My NAND flash chip is SKhynix "H27U1G8F2C" , but there is no exactly the same marking between supported chips of my programmer. The most similar is "HY27U1G8F2B". I don't know, if second 'Y' in the label is something different, but last character 'B' means die generation, C is modern, than B, but maybe its not such a big deal.
            ( supported chips )
            • lotas
              • Jan 2016
              • 4852
              • Russia
              #26
              Yes, well, try to carefully dismantle the NAND without damaging the adjacent components and read the contents, and how many (BB) Bad Blocks it has.
              • YellowJacket
                • Dec 2020
                • 107
                • Slovakia
                #27
                Thank you, have to etch some pcb board to fit NAND there, since I have no board like this, to connect it to my programmer. Will response as soon I read the content.
                • lotas
                  • Jan 2016
                  • 4852
                  • Russia
                  #28
                  https://aliexpress.com/item/1005003717097551.html
                  • nomoresonys
                    • 12328
                    • U.S.
                    #29
                    Lotus is there some definitive test to determine if it's the nand before removing and using programmer or is like a high percentage that it's a nand or some type of memory problem when you get the boot loop?
                    • YellowJacket
                      • Dec 2020
                      • 107
                      • Slovakia
                      #30
                      Well, I wanted to speed up the process by etching a PCB for reading the NAND, but my programmer can not identify it ( there is some picture of original adapter in programmer software, and there should be made some modification even on original adapter, so ... few hours of working on it are in ... ).
                      I have to wait for adapter from China, so I guess, I will revive this thread later. Thank for all your help so far.
                      • nomoresonys
                        • 12328
                        • U.S.
                        #31
                        Never mind, took an online course and refreshed my memory.
                        • YellowJacket
                          • Dec 2020
                          • 107
                          • Slovakia
                          #32
                          Small update - there was some USB plugged in in time, while my friend realised, that TV is restarting. So definitely TV stops working only during some kind of usb plugged in.
                          Can I consider this to pure software issue then?
                          • nomoresonys
                            • 12328
                            • U.S.
                            #33
                            well if the only problem is it won't play nice with a certain thumb drive or play some files from it that the tv isn't designed to play, then probably so. Like the old prescription, guy goes to doctor and says doc it hurts when I do this, doc says just don't do that, pay at the desk.
                            • YellowJacket
                              • Dec 2020
                              • 107
                              • Slovakia
                              #34
                              Haha, yes, I told to my friend to not use any USB until I got that adapter from aliexpress to read NAND flash. I believe, it can be fixable with help of you guys. Thank you all so far, will update this thread, when I read NAND. Bye.
                              • lotas
                                • Jan 2016
                                • 4852
                                • Russia
                                #35
                                Quote from LG:
                                "It can also be a problem if your external drive is too large. Some LG TV models do not recognize flash drives larger than 32 GB and hard drives with a capacity of 2 TB."
                                It will be necessary to check with a smaller USB Flash (16-32Gb).
                                • YellowJacket
                                  • Dec 2020
                                  • 107
                                  • Slovakia
                                  #36
                                  I did, and it worked fine. Probably its normal behavior with larger storage. Looks, like I wasted your time with this thread, gentlemen. I am really sorry. Anyway, you learnt me something new, so I am very thankfull to you.
                                  • nomoresonys
                                    • 12328
                                    • U.S.
                                    #37
                                    no problem at all, that's what people are here for, to solve problems and learn things AND sometimes to tell others I told you so.
                                    • nomoresonys
                                      • 12328
                                      • U.S.
                                      #38
                                      I was eluding to as much in post 10 but I didn't want to say your friend was just not grasping the simple solution.
                                      • SidneyCanadas
                                        93C46 and 93C56 EEPROM
                                        by SidneyCanadas
                                        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                        06-14-2023, 01:16 PM
                                      • rounin
                                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                        by rounin
                                        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                        🛠 Original Issue
                                        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                        04-19-2025, 01:18 AM
                                      • ugamazing
                                        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                        by ugamazing
                                        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                        12-17-2024, 07:05 PM
                                      • shahnld
                                        Lenovo legion 5 pro startup issue
                                        by shahnld
                                        Good day Experts
                                        I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                        A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                        And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                        08-24-2025, 12:31 PM
                                      • ahmarzo
                                        Acer laptop battery draining issue
                                        by ahmarzo
                                        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                        08-02-2025, 06:39 AM
