Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
  • gbbradshaw
    replied
    Re: Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
    Originally posted by Diah
    his TV blue screen 99.9% damaged U ribbon / LVDS Pins cable. take all out and under good light and loop inspect them... don't trust your glasses...
    use magnifier.
    pls for feature photos upload use advanced setting and upload photo over this forum
    Thanks for the reply. I will have to try this, but is this the case? I am asking because, if I remove the big white lvds cable nothing changes, so I guess the CSF01 ( ribbon cables) might not be the problem.
  • gbbradshaw
    replied
    These are the pictures. Tried to focus as much as I could.
  • Storyteller12
    replied
    You can try taping pins on lvds cable going to panel to see if you get any sort of picture.
    It’s a trial and error kinda of thing. So might have to try several times covering different pins
  • Diah
    replied
    use magnifier.
    replied
    Originally posted by gbbradshaw
    Is this the right way to do it? Please check the picture
    I know that if the caps beeps when I use the multimeter, in most occasions its a bad capacitor.
    I also know that if I set the multimeter to 20k to check the ohms and the value is not going from 0 to higher, that's also a bad cap.
    Correct / guide me if I am wrong please. Thanks
    yes, this I call a dirty test but I have found bad caps this way, if you have some caps that size it sure shouldn't hurt to go ahead and change them out.
    replied
    fuse on powerboard is ok, could check on mainboard, sometimes theres a bunch of little fuses that you can check on some mainboards, they will be labeled starting with a Fxx, if they're labeled.
    replied
    you can check caps with the same setting of V, just not sure I would check the main filter caps on powerboard with that meter, they usually are around 400 volts when tv working.
  • gbbradshaw
    replied
    black neg. lead in com, red pos. lead in V. might not want to measure anything that might be over 300 volts with that meter but you can still check a lot of stuff with it.
    That's right, for checking the voltage. But for the capacitors, is it right to do like in the picture?
    For the voltage check I am afraid you will have to tell me what and where to check after I will provide the photo of the boards if that's alright. I usually look to check for fuse on the pcb , but I couldn't find one.
    replied
  • gbbradshaw
    replied
    you could check the little mlc caps on the panel driver boards for shorts or very low ohms.
    replied
  • gbbradshaw
    replied
    But OUT d pee, if you don't want to help, keep your SARCASM to yourself.
    Thanks dude! Just stay tuned, I will upload the pictures at around 6pm uk time.
  • gbbradshaw
    replied
    Originally posted by Davi.p
    don't waste money buying a main board, it's almost surely the panel, since you are not a tech and the fault is very difficult i suggest you to sell the whole thing as a defective unit.. bye..
    I am not sure I want to sell it for £50 while I paid more than 10 times this price last year. I am sure there are specialists in here who might have encountered this kind of problem over the years and that might be able to help. Thanks for replying though.
  • Davi.p
    replied
  • gbbradshaw
    replied
    Originally posted by yokoono
    Is CN1 closed correctly?
    Yes , everything was cleaned with contact cleaner and put back together as normal to the lines.
  • gbbradshaw
    replied
    easy stuff first, try a simple reset, with tv unplugged, hold power button on tv for 30 seconds, then plug it in and try it.
    Already tried that, more than 60 seconds.
  • gbbradshaw
    replied
    yep, make sure those cables are positioned correctly, can clean them too: https://www.youtube.com/watch?v=aOCLpJub2l0
    I have already did that last night just to tick this off the to do list. No success with that. One thing I have to mention, removing the white lvds cable , the long one, does nothing. But with it connected, when I switch through the tv channels I can see the screen light changing from dark blue to lighter. Which mean somehow thr pcb board is not sending enough signal to the display.
  • gbbradshaw
    replied
    should probably do some voltage checking before removing anything.
    I will do clear pictures and then maybe you can guide me to do so please.
    replied
    replied
  • mar1in
    Samsung TU8000, backlight and sound on, stuck in blue screen
    by mar1in
    I've got this Samsung here that would be stuck in a boot loop.
    After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
    Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
    Thanks in advance
    11-08-2023, 05:43 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • Chrissygizmo
    samsung galaxy ao2s very temperamental after screen replaced
    by Chrissygizmo
    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
    Ive eventually managed to get it on and working but it's very temperamental...
    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
    05-26-2024, 12:05 AM
  • bohaboha
    Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
    by bohaboha
    Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
    anyhow i couldn't t read anything else
    the backlight is on strong and the screen does not get dark or very dark but no pictures
    the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
    01-02-2025, 08:04 PM
