Re: Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
Ckv1,2,3,....
Originally posted by Davi.p View PostSome lines can have no influence, the lines to be blocked are the clock lines usually are 8 but can be less, check on the screen's small boards if there are test points named CKVxxx you can also discover to which pins are connected by using multimeter..
LE: unfortunately these are not called CKVxxLast edited by gbbradshaw; 02-26-2023, 05:14 AM.
Originally posted by Davi.p View Postif no markings ---> dog penis method (random)
Originally posted by Davi.p View Postno you' ve not understood, the faulty part of the screen is the right part, so you have to put tape only on right half and not so, you start from far of side and shift 1 pin per time only not 8.. but only 8 pins covered..
https://youtu.be/XCJAx92JwPs
Originally posted by gbbradshaw View PostI am afraid I have only removed the u ribbon from right side as I ran out of time to do so for the left side aswell
I will try this tomorrow. So patch 8, then another 8, only from on side of the u ribbon, until it gets fixed? Please look at picture.
Originally posted by Diah View Postare you heavy weight person lol..... the place were u worked before on u ribbon... i can see there are signs
if you were slim which i don't think so... then sorry ignore what i wrote. lol
Talking about the u ribbon , i don't see any signs as I have not worked on them, maybe just some fingertips
Originally posted by Diah View Postthx for photos
sorry to say.. your hand very heavy at work.... u keep it so no fix.. or u try while it on. smoothly make pressure on the u ribbon or in the cofs ribbon which goes to lcd from both side.. if u find any better change.. try to fix it by load.
thx for photos
Originally posted by Diah View Postshow us clear photo of the left side panel puffer boards when u look on it from back side
Last two are from the right side of the back( left side front)
I hope when you said puffer boards, you meant this.Last edited by gbbradshaw; 02-24-2023, 05:05 PM.
No it's not you Gbb, it's that goofy guy that keeps crying panels shorted every time he sees a line or two, which it could be a bad panel but could also be a LOT of other things as well, we all know his name.Last edited by nomoresonys; 02-24-2023, 05:07 PM.
Originally posted by gbbradshaw View PostI completely agree with you, but there's nothing else I can do but try things. So far, the only thing that worked was changing the MB, now I got back to having an image. I would also change the caps on the lower boards where the the flex ribbon connects, but honestly I don't see which caps are they or the name, so I can order some.
Originally posted by nomoresonys View PostDespite what one member says, lines on the screen even lots close together doesn't instantly mean a bad panel, it could be as simple as a bad cap on panel driver boards which technically is a bad panel, or cap on mainboard or cap on powerboard or something else on one of the boards, those who jump to conclusions quickly, NEVER make good troubleshooters.
Despite what one member says, lines on the screen even lots close together doesn't instantly mean a bad panel, it could be as simple as a bad cap on panel driver boards which technically is a bad panel, or cap on mainboard or cap on powerboard or something else on one of the boards, those who jump to conclusions quickly, NEVER make good troubleshooters AND they are sooo f@#king irritating.Last edited by nomoresonys; 02-24-2023, 05:05 PM.
Originally posted by Davi.p View Postthe bad side is the right side
I will try this tomorrow. So patch 8, then another 8, only from on side of the u ribbon, until it gets fixed? Please look at picture.Last edited by gbbradshaw; 02-24-2023, 03:44 PM.
