2 red blink code on old led tv Sony KDL-40W2000
  • reporter1979
    • Feb 2023
    • 11
    • Italy
    Hi all, the TV KDL-40W2000 was flashed by a lightning.
    Firstly I got the 3 red blink code.
    Following other threads I changed the power supply board and got always 3 blinks.
    So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
    The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
    What else can I do?
    • 12330
    • U.S.
    Re: 2 red blink code on old led tv Sony KDL-40W2000
    try a firmware update/pair, might be something else, but sometimes the surge just messes up the firmware and they always advise updating when changing out the mainboard.
    • reporter1979
      • Feb 2023
      • 11
      • Italy
      Thank you for the advise! I'll try tomorrow 🙂
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        • lotas
          • Jan 2016
          • 4861
          • Russia
          Fault: does not turn on, gives error 2 (LED blinks 2 times).
          Reason: the TV does not turn on due to the failure of the DC / DC converter IC4500 (BD9775FV) on the B2H-BOARD board, error 2 (VD1.8, DE5V / 6V Voltage Trouble (DCALERT2)).
          You can check the IC4500 by removing the signals from the following pins: 12, 13, 14, 17, 25 and if at 12.13 (high level), at 14 (input voltage), at 17, 25 (no pulse generation), then the microcircuit is faulty.
          Solution: Replace IC4500 (BD9775FV) P/N: 6-707-927-01.
            • 12330
            • U.S.
            yep, same deal there with schematic: https://electronicshelponline.blogsp...-blinking.html I always start with the simplest things first ala Karl Childers, as in make sure it's not just the firmware.
            • reporter1979
              • Feb 2023
              • 11
              • Italy
              So probably they sold me a bad board
                • 12330
                • U.S.
                could be, do they have another they can send you if you send that one back, never pay twice tho.
                • reporter1979
                  • Feb 2023
                  • 11
                  • Italy
                  Since the TV has not usb port, I found a service input but don't know how to use it, any suggestion?
                  • lotas
                    • Jan 2016
                    • 4861
                    • Russia
                    These models were updated through this socket using a "Memory stick"
                    • reporter1979
                      • Feb 2023
                      • 11
                      • Italy
                      Thanks! Found on Amazon an microSD adapter
                      • lotas
                        • Jan 2016
                        • 4861
                        • Russia
                        This may not work, here you need an original Memory stick of a small size (up to 512 Mb).
                        • reporter1979
                          • Feb 2023
                          • 11
                          • Italy
                          I understand but it's my only option as it's hard to find original ones and mostly I have nothing to write them on 😅
                          • reporter1979
                            • Feb 2023
                            • 11
                            • Italy
                            Update: Today I turned on the TV with the remote sequence for the service menu and it started the 1-blink error code. What do you think?
                            • cheeky2
                              • Dec 2012
                              • 339
                              I totally agree. As I tried to update firmware and the speed of the new memory cards is too fast! I had to resort to getting a 128MB old memory card that worked a treat from a Sony camera at a car boot sale. Hard to find them though!
                              • reporter1979
                                • Feb 2023
                                • 11
                                • Italy
                                I have the adapteer now and I ordered also a microsd of 128 MB hoping to emulate an old memory stick. Anyway I don't know how to start the f/w upgrade process as the tv enters the red blinking very soon.
                                • cheeky2
                                  • Dec 2012
                                  • 339
                                  I have the adapter now and I ordered also a microsd of 128 MB hoping to emulate an old memory stick. Anyway I don't know how to start the f/w upgrade process as the tv enters the red blinking very soon.
                                  As stated previously it will not work as I have tried! The memory sticks that are later are too fast. I have been down the same route as you without any success. If I recall you place the memory stick in the slot by the tuner module ensuring the power to the TV is off (plug is removed from the TV). Plug the TV into the mains and wait. The rest is down to patience around 5-10minutes if I recall as it has been a while.
                                  Obviously you will need the correct firmware for this model of TV assuming you have it, which maybe hard to find as Sony have withdrawn all support for them on there website a few years back as I recall!
                                  • cheeky2
                                    • Dec 2012
                                    • 339
                                    Though reading your original post if you have a 2 blink code then it will be one of two things as Lotas has stated which I have never found in his post 5 or the main board failure. On every occasion for this model I have found it to be the main processor failure on the main board which I have had on similar boards of the same range with only Freeview reception and not satellite reception as some of this range have Freesat. The satellite (Freesat) range have firmware issues, which yours is not.
                                    So I think you are barking up the wrong tree check your pins on the IC4500 28 and 27 will be shorted to ground by the processor, which I have found previously.
                                    • GoodCapDude
                                      Sony XBR-75X940E intermittent 6 blinks error code
                                      by GoodCapDude
                                      Hi everyone. First post on Badcaps!
                                      I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                      09-20-2025, 06:07 AM
                                    • cloo
                                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                      by cloo
                                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                      After doing a factory reset this problem was gone and the picture was back to...
                                      01-06-2025, 06:02 AM
                                    • Curtissimo
                                      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                      by Curtissimo
                                      Hi everyone.
                                      I have a HP Elitebook 850 G8.
                                      Serial: 5CG2324XM0
                                      ProdID 6L8D5EC#ABA
                                      It has a Winbond W25Q256JVEN Chip.
                                      I need to remove BIOS Password.
                                      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                      Attached my dump.
                                      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                      What I did:...
                                      08-26-2025, 04:42 AM
                                      LCD LED TV Service Menu Codes
                                      ALL LCD LED TV SERVICE MENU CODES
                                      Service Menu Code with Board Name
                                      China Universal Board / Jumper Board Service Menu Code
                                      Changhong Ruba Service Menu Code
                                      Ecostar LED TV Service Menu Code
                                      Orient LED TV Service Menu Code
                                      Haier LED TV Service Menu Code
                                      TCL LED TV Service Menu Code
                                      Samsung LED TV Service Menu Code
                                      LG LED TV Service Menu Code
                                      Videocon LED TV Service Menu Code
                                      Supra LED TV Service Menu Code
                                      Toshiba LED TV Service Menu Code
                                      Symphony LED TV Service Menu Code
                                      Veste/ LED TV Service Menu Code...
                                      10-31-2024, 03:58 AM
                                    • Storyteller12
                                      Sony XBR-65X900E 4 Blink Code
                                      by Storyteller12
                                      I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
                                      I don't work on Sony much but assumed it was backlights from what I read.
                                      Opened up the TV and tested all the backlights with led tester and the all work.
                                      I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
                                      So anyway to test these lights similar to the way we test...
                                      12-31-2022, 02:17 PM
