Samsung 55KS8005TXXE power cycling
  • baldharry
    • Jan 2023
    • 17
    • .fi
    Hello!
    My second TV to fix, first one was a success So the problem with this one is the power cycling. At first I did the led test, plug out MB (mainboard) and plug the powercable. Backlights turn on and TV stays on.
    At the moment MB is plugged in, standbylight turns on, TV turns off for a couple of seconds and then tries to start. Backlight flashes bright, dims out and TV turns off while PSU is having a faint ticking or clicking noise. TV stays off for a couple of seconds and tries to start again. This power cycle happens for as long powercable is plugged.
    I disconnected everything else except IR-cable from MB, same behaviour. This made me think problem lies in the MB and ordered a new one. But the new MB did not make a difference. Same behaviour. So I think the problem is after all in the PSU.
    Capacitors are tested and are OK. I took voltages which are fine with MB unplugged. Attached is a picture with voltages in three different states. PSU has a jumper wire where standby is supposed to be measured, saying it should be 7.5V and at power on it goes up to 11.8V. When measured they are 8,9V and at power on 12,84V. Is it supposed to be like that?
    Otherwise, voltages seem ok when MB is unplugged. Even in standby they seem about right? But at power on, things go weird. Voltages drop to a certain point at power off and rise again at power on. I'm baffled, please help!
    Thanks in advance.
    • 12206
    • U.S.
    Re: Samsung 55KS8005TXXE power cycling
    with tv unplugged from power which it should be any time connecting cables, unhook one at a time of the wide flat cables and try tv, so youre trying it with one cable unhooked then plug it back in and try it with other cable unhooked.
    • Storyteller12
      • Jun 2020
      • 624
      +1
      • baldharry
        • Jan 2023
        • 17
        • .fi
        Argh, forgot to write that in the first post. Tried with only one cable at the time, no difference. Tried with both off, no difference
          • 12206
          • U.S.
          ok, thats probably a good thing, probably no panel damage.
            • 12206
            • U.S.
            I kind of suspect that its a mainboard issue, try the hairdryer test, with everything plugged in heat up the electrolytic caps on POWERBOARD for a couple minutes then try the tv, don't wait til it cools off, try it while its still hot but your powerboard looks good to me.
              • 12206
              • U.S.
              does the place where you got the mainboard have another they can send you if you send that one back? but don't pay twice, if they do have another available, send one back and they should send the other out.
                • 12206
                • U.S.
                do try it with the panel button cable unhooked, the one with volume channel up down etc, sometimes they go bad and are to blame for the cycling.
                • baldharry
                  • Jan 2023
                  • 17
                  • .fi
                  Ok, heated with hairdryer but the capacitors don't feel that hot, can easily hold finger on them without burning. Same effect. Heated for about 3-4 minutes.
                  The seller (Aliexpress) said the boards are tested. Getting a new one takes about 4 weeks to arrive.
                  It has only power button. Disconnected but cannot power it up so TV stays in standby now
                    • 12206
                    • U.S.
                    ah ok, so this one has only power button and has to be operated with remote.
                      • 12206
                      • U.S.
                      I see, sometimes the boards can get damaged in transit, did it arrive in a anti-static bag?
                      • baldharry
                        • Jan 2023
                        • 17
                        • .fi
                        Errm, can't remember. Any ideas how to test it?
                          • 12206
                          • U.S.
                          and you're sure that the replacement board is a match? usually you need to match the alphanumeric digits on a sticker on the board, not sure if the one in the picture has one, I just see the QR deally.
                            • 12206
                            • U.S.
                            and you tried it with the wifi board unhooked?
                            • Storyteller12
                              • Jun 2020
                              • 624
                              Disconnect both lvds cables going to the panel and try to power on. See if the backlights stay on or if you can hear anything on the speakers.
                              • baldharry
                                • Jan 2023
                                • 17
                                • .fi
                                Yes, by sticker number on chassis and labels on mainboard. Seller wanted pics of the original board to use for comparing. Seller had compared some resistors and capacitors different places on the board.
                                As written in first post, disconnected everything except IR-cable. Also tried disconnecting only one of them in order.
                                Did this a couple of posts above. No difference. Backlights stay on ONLY when mainboard is unplugged
                                  • 12206
                                  • U.S.
                                  well if the cable from powerboard to mainboard is ok, then it must be the mainboard at fault.
                                  • baldharry
                                    • Jan 2023
                                    • 17
                                    • .fi
                                    Yeah the cable is tested with continuity and seems ok.
                                    Oh crap, but how can they both be broken the same way? Any clues where to start "debugging" the mainboard?
                                      • 12206
                                      • U.S.
                                      its tough, here's a little of what Tampatac went thru, I can't see if he made another video on this tv or not, last thing he says I think, is that he's going to try to fix the mainboard but I don't see the next video, he may have gave up, not sure: https://www.youtube.com/watch?v=-_e9DFeZYKI
                                        • 12206
                                        • U.S.
                                        Diah or Lotus might have a better idea on whats wrong, mainboards are not an easy tackle.
                                        • valvashon
                                          Samsung UN55FH6030: random power cycling
                                          by valvashon
                                          Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
                                          About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
                                          Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
                                          10-20-2023, 09:59 AM
                                        • high-tech
                                          Samsung UN55F7050AFXZA ver. TD01 power cycling
                                          by high-tech
                                          Hello everybody, I could use some help on this one... It's got me guessing...
                                          I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                                          (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                                          (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                                          (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                                          (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                                          9. ground (PWM2) 10. 0.9 volts cycling...
                                          09-15-2020, 03:39 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • MrBrick
                                          Samsung UE55RU8000 power cycling (turning on and off)
                                          by MrBrick
                                          I've owned this tv for 3 years when all of a sudden it started power cycling - with no apparent cause. It's not in warranty.
                                          I know this appears to be a fairly common issue, but would appreciate some guidance as I have no idea what i'm doing.
                                          I have taken the back off and when either of the two ribbons connected to the main board are disconnected, no image other than the back light appears on the screen, but the sounds runs. This happens with both ribbons and when they are both in place, the power cycling starts again.
                                          Is there any recommendations on...
                                          10-23-2023, 07:59 AM
