L32 HDTV10A Nightmare
  • Zumaz87
    • Aug 2010
    I recently bought the darn thing from an acquaintance knowing that the TV was receiving no power. Quick trouble shooting found that there as multiple problems with the power supply. Easy enough fix.
    Once i got the replacement parts in, like trends in other Vizio products, the amber light for standby was there. Once i pressed the power button the light would turn green ... ... and that is all. No other response what so ever.
    I talked to the previous owner and asked about what may have happened to the TV before and he simply brought over the original main board. Neither the Original or the Replacement that was in the TV have any Sort of damage or ware of any sort to them. voltages check out and i honestly don't know where to go from here.
  • PlainBill
    • Feb 2009
    • 7034
    Re: L32 HDTV10A Nightmare
    Ahh, crud. My best advice - get your money back. I'd say there is a significant chance that proper handling precautions were not taken when the original main board was removed.
    Two things to try. Turn the TV on on a dark room with the back off the TV and watching from the back of the TV. Do you see anything that could be a flash from the backlights?
    Hook up a signal source - DVD player, video game, whatever to one of the inputs. Step through the inputs. Do you hear the sound at any point?
    PlainBill
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
    • techpointhull
      NO POST Nightmare - DFI G7L330-B Industrial Motherboard Socket 775
      by techpointhull
      Hi Guys,
      Newbie here to board repair so bare with me. I have a bunch of Socket 775 motherboards from arcade gaming machines. The brand is DFI, and it's their industrial motherboard range model number G7L330-B
      All boards have the same issue, no POST. I've re-capped the boards completely, can't see any shorts across the 12V rail and I've removed all MOSFETS from the board to test them. The boards have been ultrasonic cleaned as well as an alcohol bath, doesn't seem to have made a difference
      BIOS is also correct, I do have a working board for reference...
      11-21-2023, 10:57 AM
    • iMuhtaseb
      [SOLVED] 820-00165 corrupted network of some sort
      by iMuhtaseb
      [SOLVED] -- I came in this morning and I installed the AirPort screw with a little push and it resolved the issue.
      Hello everybody!
      I hope you all having a great day.
      820-00165 came with a black screen problem; the computer would operate normally but sometimes it gets stuck in a black screen for some reason..
      (I did not verify this issue when I turned on the computer until later on)
      After disassembly and doing visual inspection I found Q1840 and U1845 had some corrosion on it and around it.. from the schematics I understood that this...
      06-30-2021, 12:54 AM
    • CraigR
      Hp ZBook 17 G3 Not turning on sort of ???
      by CraigR
      I have an hp ZBook 17 that will not turn on with the power button. I do have a charge light. I have the board out and the switch is good then I found something not making sense to me. A mosfet (see pic) has 19.9volt at the drain but nothing at source or gate HOWEVER if I touch the gate and ground with my bare finger I suddenly get power and can turn on the laptop with the switch and boots and runs fine. I did replace mosfet but same results. Not sure why the small resistance in my body to ground would get it going?...
      03-29-2022, 03:14 PM
    • dicky96
      What sort of capacitors are these?
      by dicky96
      Guys, what sort are these - so I can order some replacements
      They are through hole not SMD. Also how do I read the markings on this type to determine the voltage.
      I take it the 270 = 270uF...
      05-01-2020, 04:27 AM
