[SOLVED] 820-00165 corrupted network of some sort
  • iMuhtaseb
    • Jan 2017
    • 125
    • Palesine
    [SOLVED] -- I came in this morning and I installed the AirPort screw with a little push and it resolved the issue.
    Hello everybody!
    I hope you all having a great day.
    820-00165 came with a black screen problem; the computer would operate normally but sometimes it gets stuck in a black screen for some reason..
    (I did not verify this issue when I turned on the computer until later on)
    After disassembly and doing visual inspection I found Q1840 and U1845 had some corrosion on it and around it.. from the schematics I understood that this has to do with debugging of some sort but I went ahead and replaced the chips anyway..
    After replacing those here where the computer started exhibiting what the customer proclaimed, the computer powers on and stays on a black screen.. after A LOT of digging I noticed the PCI slot for AirPort had some corrosion inside of them.. As soon as I removed the AirPort card the computer POSTed normally.. I tried my best cleaning the line but it was unsuccessful, so I just went ahead and applied some low melt solder on all pins and applied 450c head from above then went to the bottom side (I applied aluminum tape all around U3210, U5490, U3540 and 3550 all as well..
    Got a new PCI installed successfully and tested for shorts and compared diode mode as well from a known-good board..
    The computer POSTs successfully but sadly does not connect to any wireless network.. It keeps putting weird IPs and saying "Self-Sorted IP" or something like that.. It seems its getting all voltages but maybe something logical have died?
    Appreciate all your help and sorry for the long post!
    Note: I tried multiple AirPort cards and different known-good OS
    Diode readings for J3501
    1 0.607
    2 0.763
    3 0.001
    4 OL
    5 Ol
    6 Ol
    7 0.330
    8 0.380
    9 0.001
    10 0.440
    11 0.440
    12 Ol
    13 550
    14 0.502
    15 0.500
    16 0.790
    17 0.790
    18 0.410
  • howardc64
    Samsung UN55JU650DF network/streaming problem
    by howardc64
    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
    07-09-2025, 12:44 PM
  • davg
    Home network connection problem
    by davg
    I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
    03-06-2021, 07:13 AM
  • japlytic
    Maximum speed should be marked on network ports
    by japlytic
    I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
    One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
    12-19-2024, 05:04 PM
  • hikomalek
    SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
    by hikomalek
    Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
    When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
    Transformer:
    |Info| Primary | Aux | AB | CD|
    |Ratio|1|25|40|12|
    |Voltage AC|230V|9.2V|5.8V|19V|
    |Voltage DC (*1.41)|230V|13V|8.1V|27V|
    I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
    09-19-2025, 03:30 AM
  • harp
    simple win network with optimization issue
    by harp
    simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
    06-23-2025, 11:01 AM
