Bn44-00289a
  • Hurricane_
    • May 2022
    • 8
    • Romania
    Bn44-00289a
    I have the source from the title because of which I had no backlight. A transformer was broken and I changed it.
    Now the backlight appeared, it's ok, except that the mosfet transistors for one of the transformers reach about 150 degrees and would probably burn if I left them.
    I changed the transformers between them, I changed the lamps between them or with new ones, I changed the transistors between them or with new ones, no change, the exact same transistors heat up from exactly the same position.
    Any idea?
    • 12116
    • U.S.
    Re: Bn44-00289a
    having a hard time visualizing it, can you post some pictures of it.
    • Hurricane_
      • May 2022
      • 8
      • Romania
      Re: Bn44-00289a
      https://www.aliexpress.com/item/4000...martRedirect=y
      • ducky29
        • Dec 2015
        • 370
        • Europe
        Re: Bn44-00289a
        Hello. What is the position of the transistor that its getting hot?
        • Hurricane_
          • May 2022
          • 8
          • Romania
          Re: Bn44-00289a
          Are the transistors for the transformer next to the 220v AC connector
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • Francesc V.
            Onkyo A8200 - Not the right voltages in some transistors
            by Francesc V.
            Hi:
            I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
            With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
            Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
            Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
            I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
            04-19-2025, 07:17 AM
          • redbaron1007
            Sundown SFB-8000D What are these transistors?
            by redbaron1007
            I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
            My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
            11-12-2023, 07:30 PM
          • Bob Wong
            MSI Crosshair 15 A11UEK. Need help with Transistors!!!
            by Bob Wong
            Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
            In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
            P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
            03-15-2025, 02:02 PM
          • hyva_ana
            Marantz PM-66SE Burns Transistors
            by hyva_ana
            While ago I replaced those big filter caps to that amplifier. After that started to happen. I connected the amplifier normally to the mains and almost immediately several transistors burned out. I really didn't do anything else (at least on purpose) than replaced those big caps C801 and C802.
            After that I replaced those burned transistors (I can't remember exactly what they were) and measured all the others, and now everything should be ok. But, when I power up that amplifier part with two bench power supplies connected in series there is obviously still something...
            02-11-2023, 06:34 AM
