Hitachi (Vestel) TV is not turning on
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    I have 32 inch Hitachi TV with Vestel PSU board 17IPS71. Tv was working normally and I shut it down normally via remote control.
    The next morning it couldn't turn ON neither with remote controller or via button on the logic board.
    There is a red standby LED ON, so it is not dead totally.
    I have examined the PSU board and I cannot find find any traces of blown components or bulged caps. Electrolytic caps are manufactured by Elite.
    I also check diodes and big MOSFET (with cooler/heatsink). It seems OK.
    Can you tell me based on your experience if the fault is most likely on PSU or logic board? Based on what I have found on the forum, these Vestel 17IPS board are not really high quality boards, so I guess problem is on the PSU part.
    Do you have any advice what should I check further?
    Thank you!
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Hitachi (Vestel) TV is not turning on
    whats the full tv model number and what mainboard number is used in this tv
    • Askic
      • Sep 2018
      • 187
      • BIH
      model is 32HYC01, 65W and the photo of motherboard is attached. I believe it is 17MB82S.
      Thank you!
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Jaime Morillo
        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
        by Jaime Morillo
        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
        The TV was stuck on the logo and I couldn't access the update menu.
        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
        The image result was good, but the image is inverted.
        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
        Yesterday, 11:38 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • sotodefonk
        Help finding the correct model of a T-Con board on my Hitachi TV
        by sotodefonk
        Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
        I opened the tv to access the board and took the shared pictures of the T-Con board.
        I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
        I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
        Inspecting...
        06-28-2024, 04:39 PM
      • massimomax
        Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
        by massimomax
        Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
        spero che qualcuno può averlo per riprogrammare eprom. grazie
        Post in English !!!
        I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
        02-28-2025, 07:27 AM
