Lost PASSCODE for Vizio VP50HD
  • FormerBroker
    • Aug 2010
    I have forgotten my PASSCODE(4 numbers) for the Vizio VP50HD model TV. The owners manual only says that if you forget, you're just out of luck. There must be a way to RESET this passcode so that certain channels can be retrieved or changes to the permissions can be updated.
    What's annoying is that when Mediacom cable 'updates/changes' their channel lineup, previously 'blocked' channels may now be channels that you DO want to watch, yet they are stilled blocked.
    ANY IDEAS ON HOW TO RESET THE PASSCODE?
    (my other Vizio unit, a VP20HD, says that you can input a special code printed in the owners manual to override the original passcode in case you forget or lose it)
  • digge
    • Apr 2006
    • 296
    Re: Lost PASSCODE for Vizio VP50HD
    Look for a default passcode in the manual. If you know you set it yourself then try the codes you normally use. Whenever i get forced to input a code to some non trivial thing i usually just do 0000 or 1234 or similar.
    Wish i could be of better help then this, maybe there is some kind of hardware reset, or maybe a restore everything to factory defaults.
    In worst case you only have 9999 numbers to try, doubt they put any lockout thing in a TV?
    • HDWerkz
      • Oct 2010
      Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
      Here's how to access the menu:
      1. Hold down the CH+ (Channel Up) and the CH- (Channel Down) buttons on the TV.
      2. While holding these buttons press the power button on the TV.
      3. After the TV comes on, let go of the buttons, and enter the TV menu as usual.
      4. You should now see a "F" in the lower right hand corner of the menu. (If not please repeat steps 1-3)
      5. Hold down the menu button on your remote for a few seconds and the Factory Settings menu should appear. From this point you can tweak whatever settings you wish.
      *CAUTION* - Make sure that before you do anything you write down the settings before you change them. I have seen it mentioned that certain settings never be adjusted. Please search the internet regarding your problem before you do anything.
      Don't change any settings from the R Offset / G Offset / B Offset Modes.
      • i440bx
        Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
        by i440bx
        Hey there,
        I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
        The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
        It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
        As written above, I plugged in a new CMOS cell and checked...
        08-19-2024, 02:28 PM
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • tusiime
        How to access Vizio m652i-b2 service menu
        by tusiime
        The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
        So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
        Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
        09-15-2023, 09:57 AM
      • RetroComputingGrotto
        New Toy UNI-T UTi260B - What Settings?
        by RetroComputingGrotto
        I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
        After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
        I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
        09-02-2025, 08:36 AM
      • JaquesPratt
        Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
        by JaquesPratt
        I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
        This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
        07-16-2024, 01:04 AM
