Vizio 32" Plasma question
  • joshthrope
    • Aug 2010
    Hey guys,
    Wondering if anyone might have any insight. I have a Vizio plasma tv that was given to me a couple of years ago and it has worked fine until one day I heard a click (Not the deadly pop). The TV went out and will not come back. On inspection I find that when I turn it on it starts to go through the startup procedure and I have 5v coming out of the power supply to the Ysus board. A few seconds later I here a second click from the power supply board and the voltage is dropped out. If I unplug the ysus board and turn on the TV, the voltage does not drop out.
    I do not have any popped capacitors on either board and do not see any sign of damage to either board. Wondering if this sounds like a simple power supply problem or do I need to trash the thing. Seems to be either the Ysus board or display issue. Any help would be greatly appreciated.
  • AJ11R83
    • Aug 2010
    • 19
    Re: Vizio 32" Plasma question
    Sounds like a short once something is switching in.
    Is it the buffer board y or y sus main? If you can get hold of a new/second hand pcb and try it, thats the way id go.
    Are you uk based?
    • cadiman
      • Mar 2010
      • 397
      We need a model number please. If you can unplug the y board and the power supply doesn`t shut down You need a y board and possibly buffer board replaced. We could help you more if we knew who made the pdp for vizio. It could be l/g, samsung, or panasonic. Pictures help too.
      Goodluck!
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Cooperr
        Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
        by Cooperr
        I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
        The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
        10-21-2025, 01:11 PM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
