UE55D6200 black screen!
  • vwstepha
    • Aug 2022
    • france
    Hello.
    I am French
    I have a SAMSUNG UE55D6200 identical to the UN55D6200
    In August 2022, the screen suddenly turned off
    The TV clicked at first but now nothing.
    I have searched many forums and looked for lots of info.
    By unplugging the Main, the LEDs did not light up.* So I changed the LEDs
    I bought 2 BN44-00457a power supply cards (1 on Ebay and the other on Ali).
    Same problem: still no leds lighting up
    I was provided with a BN44-00428a which can be installed on my TV but I do not have the same connectors
    for the leds, originally I have 2 wires per led strip so 4 wires
    on the bn44-00428a I have 2 connectors of 12 or 16 wires
    Same for Main:
    on the BN44-00428a there are 2x more wires than on the origin
    I know that my power supply board is compatible with the BN44-00424a
    Can I use the BN44-00428 for my TV and how to connect the cables?
    Thank you
    In order:
    BN44-00457a
    BN44-00424a
    BN44-00428A
    BN44-00428A
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4514
    • Italy - Milan
    Re: UE55D6200 black screen!
    with original board test it with dummy loads on the main b. connector
    • vwstepha
      • Aug 2022
      • france
      hi sir!
      what type of dummy load?
      and connect to which terminal that goes on the Main Board?
      tks you!!!
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4514
        • Italy - Milan
        For 5v resistors, for 12v a 12v lamp
        from my notes:
        TEST-PSU - Resistenze da usare: 5v/0,8A= 2x3ohm/2W serie; 5v/,9A=5,6ohm/5W; 5v/1A= 5ohm/5W; 5V/1,5A= 3,3ohm 10w; 5v/2A= 2x2,5ohm/5W parall; 12v/1,25A= lampad. 15w o 3x5w in parall.; 12v/1A= 4x3w parall.; (valori approssimati x brevi test)
        you have many choices, for each output around 1A is ok
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
