Not only motherboards but...
  • mbates14
    • May 2005
    • 169
    Not only motherboards have bad caps is right.
    Im sure your all familiar with the older Sony CCD-F77 series camcorders. WOW what a sight. All 100 or so caps were leaking and bad, I had to recap the entire unit.
    what made it even more fun, I couldnt find the SMD kits anymore with all teh replacement caps, so I had to use all radial caps. talk about a space hog. And to top the cake with the icing, about 20% of the caps, the pad came with it!!
    but not surprisingly, it works again.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    we are gonna have to see PICS OF THAT!!!!!
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      welcome!
      btw i have a video watchman i need to recap.
      thats a sony 8mm/tv handheld.
      lots of dead smt lytics.
      • mbates14
        • May 2005
        • 169
        i cant give you pics, i dont have a digital camera anymore. it got stolen.
        I live in hamilton, or "hamiltucky", so that comes to no surprise around here.
        • mbates14
          • May 2005
          • 169
          trust me, you dont want to see pics of that. its a monstrosity.
          I still have 3 left in the y-process section. 3.3uf, 10uf, and a .22 uf around the IC. i ran out of room, so I couldnt replace it. i can tell they are wasted, because when I record from the camera head, its got lines in it. kinda. (noise lines, like a bad rca cable would give). it records from the RCA jacks perfect now, and playsback perfect, and the camera's output is perfect. but it wont record properly, I know its those caps.
          and to top it all off, when resoldering one cap in the record RF section i took an SMD resistor with it. and the pad
          so I put a big resistor in there, and hot glued it. that VA board looks like a biiig mess, BUT it works!
          I only had like 3 SMD caps that i pulled off of an old ps2 board.
          the rest were radials i pulled from fairly recent computer cards. and I pulled about 30 10uf caps from an older sony surround reciever. all ESRd near perfect.
          • bushytails
            Moderator
            • Dec 2004
            • 217
            oh yes we do want to see pics.
            --Randy
            • mbates14
              • May 2005
              • 169
              send me a digital camera, ill send pics.
              • mbates14
                • May 2005
                • 169
                your all moderators. I feel left out
                • madscientist750
                  Replacing electrolytic caps by solid caps on old motherboards
                  by madscientist750
                  I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                  I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                  I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                  10-19-2025, 06:10 AM
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
