REMOVE PASSWORD EPSON EMP-400We
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    HI
    anyone here know a way to remove password protection on epson emp-400We ?
    thanks
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: REMOVE PASSWORD EPSON EMP-400We
    See picture
      • 31032
      is the "We" for eductation?
      maybe re-flash the firmware with "W" version if it exists?
        • 31032
        ah yes.
        The EMP-400W is basically the same device as the 400We —sans the security features.
        also found this:
        The factory default password is to hold down the number button and press 1793 on the remote control
        • dycc
          Vision
          • Nov 2011
          • 625
          • Côte d'Ivoire
          i saw also that . but what is "THE NUMBER BUTTON"
            • 31032
            one of the buttons on the remote may act as a shift key.
            obviously it cant be 0-9, so there are only 5 others to try
            i wonder if the original control pcb / switches are still under the orange panel?!
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              will try to remove the panel
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                board pictures.nothing under the orange panel only diode led
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  We had these in the school where I worked. We used the remote control to unlock them.
                    • 31032
                    those 2 test points look interesting!
                    PW-RST & PW-NMI
                      • 31032
                      page19
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        Pw-rst & pw-nmi
                        for sure . I will take the risk to short them and see what will happen, even if i am not sure that i will remove easily the password this way
                          • 31032
                          i think it will always have a password, but if you reset it then atleast you know what it is.
                          • ramoon20
                            • Feb 2022
                            • 8
                            • Maroc
                            Hi ser.
                            I need help ,i have epson emp 400we ask for password i try hold down num botton and enter 1973 or 0000 but nothing no error nothing just screen show that epson emp 400we have password
                            need how reset password to factory default or if someone have a dump eeprom or firmware for epson emp 400we
                            Thanks alot
                            Best Regards
                              • 31032
                              read the thread from the begining, there are reset pins inside.
                              • ramoon20
                                • Feb 2022
                                • 8
                                • Maroc
                                Hi ser.
                                Thanks a lot for your quick reply first
                                Yes ser i see Pw-rst & pw-nmi can you pls montin it in image above?
                                need to know where is reset pin inside mainboard
                                  • 31032
                                  other side of the board, near the front
                                  https://www.badcaps.net/forum/attach...5&d=1461333256
                                  • ramoon20
                                    • Feb 2022
                                    • 8
                                    • Maroc
                                    Hi ser.
                                    thanks alot for your relpy first and thanks so much for your given times
                                    iwill be greet if you show me where dose reset pine it is exactly ?
                                    can you pls edit image by paint and indicating where must short pin it is?
                                    here is readed eeprom if somene can edit it
                                    Best Regards
                                    • ramoon20
                                      • Feb 2022
                                      • 8
                                      • Maroc
                                      Hi ser.
                                      I still waiting for how reset password for epson EMP 400we
                                      best regards
                                        • 31032
                                        still waiting for you to look at the pcb - it's clearly marked on it
                                        • snpetit
                                          Asus FA706IH Bios Password remove
                                          by snpetit
                                          i need some help :-/
                                          i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                          Could you please remove all password related stuff from this bios. A hate Asus....
                                          Thanks in advance!...
                                          01-10-2025, 09:17 AM
                                        • longmt1990
                                          Panasonic Cf-w5 bios password remove
                                          by longmt1990
                                          Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                          I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                          Please help me remove bios password.
                                          Thank you so much
                                          07-06-2025, 10:50 PM
                                        • fx1982
                                          ASUS ZEPHYRUS G16 GU605MV bios Admin password remove pls
                                          by fx1982
                                          Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
                                          It's a 2024 Asus Zephyrus G16
                                          GU605MV
                                          SN: S2NRCX035924088
                                          CN: AEDW
                                          MFD: 2024-02 36M
                                          BIOS VERSION: 315...
                                          06-05-2025, 10:46 AM
                                        • AJ847.63e
                                          Is it possible to remove admin accounts without password on Mojave?
                                          by AJ847.63e
                                          Hi All,
                                          Just wanted to ask is it possible to remove admin user accounts on Mojave when you do not have the admin password for the account you want to remove? We have our own account setup as an admin but the customers setup their own also as an admin.
                                          We have a loaner A1708 we leant to a customer while we were repairing her A2442. Customer decided she would setup her own account despite me setting up an account for her. We obviously do not have her password and unfortunately, she cannot remember what password she used so now we have a second admin account we would...
                                          03-13-2023, 10:40 PM
                                        • ritalo
                                          MacBook Air 13 2014 - Remove EFI password
                                          by ritalo
                                          I have a MacBook Air 13 inches 2014.
                                          I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                                          I know how to remove the password with a usb programmer.
                                          I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                                          Then I have to find this value in the file : $SVS because it indicate where is the password.
                                          But I can't find the value.
                                          I have attached the file​
                                          Thank...
                                          05-14-2024, 12:10 PM
