Pantum P2502W Toner Reset Chip help
    Re: Pantum P2502W Toner Reset Chip help
    Originally posted by timschuerewegen View Post
    Try this checksum. It should be correct.
    May I ask, how did you determine the correct checksum?
      I used the firmware checksum calculation function.
        Ok thanks, is that tool only good for pantum images? or work with other firmware images?
          What tool? I looked at the disassembled Pantum firmware in Ghidra to see how it calculated that checksum.
            Originally posted by kad09 View Post
            Overwriting the serial number in base64 will not help, the rest of the contents are encoded by the firmware program.
            what will help??
              00 AC 00 09 AA AA AA AA SS SS SS SS 00 00 00 00
              AA = address (big endian)
              SS = size (big endian)
              I extracted the ACL command/function information from a debug build of the firmware.
              tell me what the command should be to change the serial number 00 AC FF 04 00 00 00 00 00 00 00 00 00 00 00
              hello, please help me deal with the Pantum printer, I'm interested in the ACL command AclSetSerialNumber 0xFF04, what should the command look like? look at an example of a file in hex and tell me where the error is 1B 25 2D 31 32 33 34 35 58 40 50 4A 4C 20 45 4E 54 45 52 20 4C 41 4E 47 55 41 47 45 3D 41 43 4C 0D 0A 00 AC FF 04 43 4C 31 39 39 32 30 37 31 38 30 30 1B 25 2D 31 32 33 34 35 58
                  in final can any one help to change Serial number of pantum printer like hp with that file
                  %-12345X@PJL
                  @PJL SET SERIALNUMBER=Z5KZBJFD100033J
                  %-12345X
                  or not
                    Brother Please Provide Me Pantum P2506w Printer Firmware. I Need Help.badly Please Help Me
                      SMDFlea commented
                      Editing a comment
                      Off topic.Start your own thread.
                    Hello guys i wanted to ask i have a modify firmware for pantum printer 2509w and the file have .FWR extension but it has the printer id so it can only be flashed on one printer with the same id printer in the file.
                    my question is can i edit the printer id in the file and use it in other printers and how can i do it
                      Örnek P2500w
                      Seri numarası CM6U008511
                      Güncel versiyon 3.A.1.7
                      Motor versiyonu 2.A.1.3
                      Hafıza 128MB
                      Program sürümü 5.8
                      swf plase
                        Originally posted by natcam View Post
                        Örnek P2500w
                        Hafıza 128MB
                        Program sürümü 5.8
                        swf plase
                        ID?
