HP Laserjet5 may be death caps?
  • gonzo0815
    • Feb 2006
    • 1600
    i was asked if i could fix an Laserjet 5. The problem ist, that it is printing shit during the first 10 to 15minutes. After this heating up periode, it is working fine.
    From my point of view, this sounds for me for typical cap caused PSu problem,
    so i offered to fix it as lon as i haven`t to bother with mechanics.
    To be honest i have no clue abouth printers, as the mechanics is scaring me ;-) .
    I know that this thing is rather old, but if they`re happyn with it, i can warrant to spend a few fresh caps to this unit.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: HP Laserjet5 may be death caps?
    Sounds like the fuser heating element is dying, and not reaching full heat right away.
    Ludicrous gibs!
    • gonzo0815
      • Feb 2006
      • 1600
      Hm, well the fuser is melting the Toner and fixes it to the paper right?
      The Problem is, that the logic board does have some problems from my point of view.
      The prínter is printing something, and the print is ok, but there are those &%$§"'##*+~ bulshit things on the paper, not the thing you actually want to get printed.
      This leads me to the wild guess, that the logic board does have a problem.
      And as always, if the caps are getting warmer, the problem disappears afer abouth 10 to 15minutes.
      So i thought, may be the power or the logic boards caps are may be worn out (an to be honest, after abouth 11 years of duty, i think this should be not that uncomon, even if HP have used good caps at that time)
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        i am surprised it lasted so long. we went through a lot of spares with a lj3 in 10 years or so. in the end it was cheaper to buy new.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          keep printer dry and death caps cannot grow in it ;-) sarcasm mode off.
          you likely do have bad caps if its ok when its warm.
          • gonzo0815
            • Feb 2006
            • 1600
            AFAIk the printouts are not that clean with that age, but obviousely this is ok for the owner.
            I once ordered him a new ink ribbon for his dot matrix printer.
            He never changed it since he got the printer.
            With those Laserjet 3 i have had not mutch fun too, especially the rubber mechanics was hardend after a few years.
            The result where masive paper jams wich lead me to a rapid disposal of those big fat printers.
            Any way, if he is willing to give this laserjet a try, i will first replace a few lytics on the power and logic board.
            If that does not help, i will not mess aroud with it.
            But from todays printer longterm quality, i am not that convicend, that i can offer him anything comparable.
            • Maxxarcade
              • Jul 2006
              • 973
              Check the power supply/caps, IC sockets on the logic board, and any connectors that may be oxidized. If there is extra ram added, try removing it to see if it fixes the problem.
              I still use a LaserJet 4 at work. Found it in the trash, and it had been rained on for a couple days. Cleaned it up, installed new exit rollers and 32MB of ram, and I use it quite a bit. Ram makes a ton of difference when printing PDF's
              • Rainbow
                • Aug 2005
                • 1375
                Fixed LaserJet 5L yesterday - it had one of the classic problems with paper feeder (unable to feed). I was surprised that the rubber parts are still looking very good. Everything that was needed was cleaning and extending one spring a bit.
                All the caps in the power supply are Rubycons.
                I also have LaserJet IIIP - it had problems with paper feeder too. I just rotated the rubber covering the paper pickup rollers (only one side gets in touch with the paper - so the other one is not worn) and it works fine again.
                • Logistics
                  • Apr 2007
                  • 721
                  DANG YOU KC! I was about to be clever and jump in this thread and post a picture of mushrooms. BEATEN!!!11ONE XD
                  • hardwareguy
                    • Jun 2006
                    • 405
                    A bad Jet Direct card can also cause WEIRD things to happen like gibberish, endless printing of the same gibberish, etc.
                    Test using the parallel interface to eliminate the Jet Direct card.
                    • severach
                      • Aug 2007
                      • 1055
                      The LJ3 is only 300dpi. No matter how good the printer is that won't do for me. I pulled my LJ5 from the trash too. I popped out the defective RAM and it prints perfect.
                      There's a place for printers just as good as this place is for caps. Read a while and you won't be afraid of the printer mechanicals any more.
                      http://www.fixyourownprinter.com/
                      sig files are for morons
                        by momaka
                        03-12-2025, 03:42 PM
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
