KPS305D Bench Power Supply
  • abbas101
    • Feb 2011
    • 49
    • Pakistan
    When Turns on Its shows approx 4volt and goes to zero. No Current and No voltage at output. Uses TNY277GN My question if any one knows the voltage between drain and source pins, Currently it is like going into loop from 0 to 330Volts. Thanks
    • Jul 2011
    • 6040
    Re: KPS305D Bench Power Supply
    Look for a diode across the output terminals or on a board that might be shorted
    This would be the first thing that I would look at
    The second thing I would do is replace the TNY277GN these type of devices have a history of going bad for apparent reason
    Or the capacitors around the TNY277GN might be the first thing that I would try before replacing the TNY277GN ic chip
    • abbas101
      • Feb 2011
      • 49
      • Pakistan
      Thanks SAM
      I checked diodes and all seems ok. I also have doubt on TNY277 but before replacing want to be 100% sure.
      • R_J
        • 9551
        If the source pin connects directly to hot ground (- of main bridge rectifier) then there is no way that the TNY277GN is dropping the 300v to 0, it's top would have blown off the top. Check the voltage across the man filter capacitors, is it also dropping? if it is staying at 300v, check the components between the main filter and the drain of ic501
        • abbas101
          • Feb 2011
          • 49
          • Pakistan
          R_J I will check and will post results tomorrow. I did the checking last time and AC circuit was ok (at least seems ok)
            • 31061
            i presume this unit doesnt have a stupid PFC circuit?
            • abbas101
              • Feb 2011
              • 49
              • Pakistan
              Hi Guys, trouble shooting is going on in slow motion. I found shortage on smd capacitor c44 and pin 4 and 5 of LM358, Remove the capacitor and checked it but it was not short. Removed LM358 and it seems ok outside the board but still there is short between pad 4 and 5. Is it normal ? please advice
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • rabsonnjala
                LENOVO IDEAPAD 100 works only on bench power supply
                by rabsonnjala
                Hie I have a Lenovo laptop
                Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                below are my readings
                with the original charger only
                JBATT1
                PIN1 0.22V
                PIN2 0.22V
                PIN3 0.45V
                PIN4 0.45V
                PIN5 O.43V
                PIN6 0V
                PIN7 GND
                PIN8...
                11-20-2021, 08:32 AM
                by sam_sam_sam
                07-01-2024, 06:34 AM
