ZD-915 Mysterious Fault
  • axeman
    • Nov 2017
    • 25
    Hi Guys,
    Hopefully someone can help me as I have swapped the psu caps , the switching IC, the soldering gun heating element, the M7 diodes on the psu and the display board. checked all caps and diodes for shorts and still I'm getting the U3 error with constant reboot. The unit stays on without the gun connected.
    A strange symptom is that when turned off the unit flicks on the display and fan only for an instant every 10 seconds or so.
    There is a ticking sound coming from the PSU when turned on with and without the gun attached. Can't remember if this is normal or not.
    There are no scorch marks or any signs of failure on either side of the boards.
    Any help much appreciated.
  • petehall347
    • Jan 2015
    • 4440
    Re: ZD-915 Mysterious Fault
    https://www.badcaps.net/forum/showthread.php?t=51202
    • axeman
      • Nov 2017
      • 25
      Thanks for getting back Pete,
      Already swapped the M7 diodes twice
      • petehall347
        • Jan 2015
        • 4440
        do they measure ok in circuit ?
        • axeman
          • Nov 2017
          • 25
          Just checked diodes in circuit and D8 looks suspect. So will remove and check.
          • axeman
            • Nov 2017
            • 25
            D8 checks ok removed.
            • axeman
              • Nov 2017
              • 25
              If the unit powers on ok with the soldering gun removed does that mean the problem is most likely on the display board side?
                • Jul 2011
                • 6069
                Replace the switching power supply regulator because this can cause it to this as well but first replace the small value capacitors around the switching power supply regulator and see if this makes a difference
                I see that you have already replace the capacitors and you still have these issues then try this what I have below
                One note test the switching power supply with two MR16 incandescent light in series and see if it will stay on or not if it does then use two sets of them and see if it still does on the two wires that goes to the heater element not the temperature sensor wires you want the heavier two wires now you will still see the error message but it should stop the restarting issue unless it is a defective controller board the light bulbs should stay on continuously and not cycle on and off
                If it does then re-hook the Desoldering Gun if it does not stays on then the issue might be a shorted heating element
                I also see that you have tried another gun and this tell me that either the switching power supply board still has an issue or that the controller board might have some type of issue but not staying on and restarting might be more of a switching power supply board issue try replacing the optic sensor or at least measure the LED side ( the input side of the device ) you should get about 1.5 to about or even a little bit more than 2.0 volts and it should be steady not jumping around when trying to load up the switching power supply board
                I have about 8 of this type of units and I seen different failure issues with these units
                Now you can try to power the Desoldering Gun Station but you will have to do the following depending what version you have there is a -5 volts power supply rail that has to used for the controller board power supply rail you will have to find the Zener diode and a 1 to 2 watt resistor on the switching power supply board has to used or the temperature controller part of the controller will not work correctly anymore
                The reason I know this is that I try to build a battery operated desoldering station and it does work however you have to use a PWM controller on the heater element if use it on battery power because the controller portion of the controller will not work correctly anymore if you try to use battery power
                If I were to power ( with a computer switching power supply) the desoldering station here is what I would do is remove all of the switching power supply components and where the low voltage filtering capacitors are this is where I would put the power supply wires at this point on the switching power supply board and everything should work unless you also have a controller board issue as well
                The reason I think you might have a issue with the controller board is if the diode shorted on the controller board I also had this happen and the controller board did have an issue with controlling the temperature correctly after that
                I hope this helps you
                • axeman
                  • Nov 2017
                  • 25
                  Thanks for response Sam et al. Just back from hols so will try suggestions over next couple of days and report back.
                  • eradiofan
                    • May 2023
                    I had this fault with mine. I purchased it in 2020 and despite restarting from time to time, I managed to use it for over 3 years before it finally packed up. Constantly re-starting.
                    Took me a whole day to track it down, using a high-votage differential probe. The continuous restart is caused by a switching regulator error condition and there are many types. In my case, the FSCQ1565RT switching regulator was losing VCC after a short time, causing a reset.
                    The circuit (from eevblog) is supposed to charge E6 via R13+D9 but this was not happening. I replaced E6 and D9 with a fast recovery diode (1N4937) and it is working again.
                    • Dvsr
                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                      by Dvsr
                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                      After replacing the caps I started testing out the speaker. It seemed...
                      09-10-2025, 10:20 AM
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • Rictech
                      Panasonic SA-MAX770PU SMPSU board fault....
                      by Rictech
                      Hello everyone. 😀
                      As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                      Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                      Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                      This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                      There are no devices that have exploded or otherwise show signs...
                      08-26-2024, 01:05 AM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
                      ESR meter came to the rescue again today with a PLC I/O card fault
                      I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                      I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                      One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                      12-18-2023, 08:17 PM
