Faulty LED floodlight driver
  • bafangrider
    • Aug 2022
    • 4
    Hi All,
    First post here.
    Got a LED floodlight that filled up with water and am trying to repair it.
    Steps taken;
    1. Cleaned up all water and plugged in to test function
    2. Driver board with no load spits out around 85VDC
    3. Soldered LED back on and the LED flashes straight away
    4. Also noticed one led on one of the rows was faulty causing the row to stop working - shorted that LED and now the row works
    5. After doing this the LED seemed to work be then flashed after about 5 mins of use
    6. Then went over the board and re-soldered all connections on the non SMD side
    7. Still flashing, so suspected faulty capacitor. All test within reasonable limits (100uf caps were around 90uf) except the MKP caps which test at 0uf
    Ive read MKP caps are for AC line filtering and shouldnt affect function so am not really sure that is my issue.
    Has anyone got any suggestions on what to try next?
    I am happy to replace the driver with a good quality replacement, but not sure what to pick as the SMD LEDs in diode mode read about 2.5V. Without knowing too much about how to size constant current drivers for LED arrays I would suspect I need something around 60-90VDC (as the LEDs are 24 in series)Looked on meanwells website cant see anything that might suit.
    • 31051
    Re: Faulty LED floodlight driver
    how long ago was it drained? maube there is still moisture in the transformer.
    also, check the solder joints carefully
    i wonder why only 1 track has lost it's laquer coating?
    • bafangrider
      • Aug 2022
      • 4
      Was drained just before working on it and powering on. On first power on I could hear a sizzling noise and noticed there was indeed some water in the transformer.
      I wonder if the transformer could be dried out or if its better to replace it? The only issue the transformer doesnt have any discernible markings for model numbers etc.
      Yes its interesting only one track has lost its lacquer coating. It is the high voltage negative from the bridge rectifier if that helps solve the mystery?
        • 31051
        i would put the board somewhere warm for a few days, or stick it in front of a fan heater for atleast 30mins to dry out
        you probably dont even have fan heaters in most of australia - not really a requirment!
        • bafangrider
          • Aug 2022
          • 4
          It hasnt been used for about a week now so maybe worth giving it a go!
          I actually have a split system in my shed because it gets down to a chilly 10 degrees some times!
            • 31051
            thats almost beer fridge temperature!
              20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
              by sam_sam_sam
              I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
              At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
              Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
              04-09-2023, 08:04 PM
            • osrex
              LED DRIVER KEEPS DYING
              by osrex
              Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
              i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
              i have no datasheet at all for the LED lights, all i have is its length.
              long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
              as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
              05-05-2025, 03:36 PM
            • Ancient1
              How to Test : Bad Backlight Driver OR Faulty_Strip
              by Ancient1
              Hi
              Its a "dumb" question , and an answer probably available somewhere ..
              Assume no Backlight Tester or exposed Strips , PSU has V/A Outputs Table.
              This transforms the question to :
              How to Test the Driver in uncovered TV ?
              Thx
              01-01-2023, 05:05 AM
            • chth96
              How Can I test PWM DM0365R?
              by chth96
              Hello
              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
              06-18-2025, 04:14 PM
            • Satvik Hardat
              Well I am dumb to buy a faulty water damaged motherboard from ebay and i need help :)
              by Satvik Hardat
              yesterday i bought this
              I was not high on caffeine but the specs we nice-
              • Processor: AMD Ryzen 5 4600H 6 x 3 - 4 GHz, Renoir-H (Zen 2)
              • Graphics adapter: AMD Radeon RX Vega 6 (Ryzen 4000/5000)
              • Ram: 16gb DDR4
              so i bought it now i need schematics and help trouble shooting this all i saw is this burned cap idk what the value is, HELP...
              03-19-2024, 05:00 AM
