PS4 pro PSU (ADP-300FR) shuts down when turning on 12V
  • lotas
    • Jan 2016
    • 4620
    • Russia
    Re: PS4 pro PSU (ADP-300FR) shuts down when turning on 12V
    The mosfet can be shorted too, all those 3 pins (6,7,8) go through low ohm resistors to the mosfet.
    Or are you confused with pins (8,9,10)?
    • Norrecito
      • Apr 2022
      • 40
      • Hungary
      Nice catch
      I have noticed this yesterday but seems like my edit didn't go through.
      The shorted pins are:
      10 - pfcOK (5 ohms to GND)
      8 - DRV (1.2 ohms to GND)
      7 - GND
      The MOSFET isn't shorted, I have desoldered and tested it before.
      • Norrecito
        • Apr 2022
        • 40
        • Hungary
        The IC has finally arrived and I had some time to replace it.
        The results are amazing, the PSU now works perfectly and even the PS4 starts with it. It displays an image mentioning that it could not find the storage. The HDD is busted (because of the same fall that damaged the PSU), not even my PC recognizes it.
        Thanks for the help guys, I could not done it wothout you!
        • Master it
          • Feb 2022
          • Romania
          https://www.youtube.com/watch?v=sx0oBXsueFk
          Hope to help u
            • Jul 2011
            • 6040
            Originally posted by Master it
            Thanks for sharing this video information very informative
            • Fico_m1
              • Apr 2018
              • 10
              • Croatia
              #26
              Hello, I have a power supply PS4 PRO model ADP-300FR.
              The part around the fet is gone, I'm wondering if anyone has a picture of this part of the power supply to see the resistor R99 and diode D63 markings?​
              Thanks a lot.
              • psina
                • Feb 2015
                • hrvatska
                #27
                r99 =10k,,zener = 5d-7 (zener 7v?)
                  • Jul 2011
                  • 6040
                  Hope to help u
                  Well done video
                  • JonnyS
                    PS4 pro PSU ADP-300CR shuts down when turning on 12V
                    by JonnyS
                    I would like to ask for your help to troubleshoot a faulty PS4 pro power supply
                    I have a st_by voltage ane when i try to power on 12v line PSU shuts off
                    i measure lot of components but i don't fins faulty piece ,
                    when i try to power on 12v line voltage increasing to ~420v so it looks like PFC was working,
                    Now i have no idea what i can do more to fix it and i will be very helpfully to help me in this case.
                    10-10-2022, 10:34 AM
                  • прямо
                    Viper22A 5VSB circuit
                    by прямо
                    So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                    In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                    01-13-2024, 07:05 PM
                  • kotel studios
                    FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                    by kotel studios
                    Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                    Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                    I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                    Any ideas where to go next?
                    02-23-2025, 11:47 AM
                    KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                    by momaka
                    For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                    http://www.rmac.kingwin.com/products.../abt_650MM.asp
                    I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                    What mostly drew me into buying it is its 2x PCI-E power connectors...
                    03-29-2022, 11:34 PM
                  • huzo
                    HP Omen shuts down when loading OS
                    by huzo
                    The model is 15ec-1061nm
                    Board number is DAG3EDMB8D0​
                    SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                    10-29-2024, 12:05 AM
