PS4 pro PSU (ADP-300FR) shuts down when turning on 12V
  • Norrecito
    • Apr 2022
    • 40
    • Hungary
    Hello all,
    I would like to ask for your help to troubleshoot a faulty PS4 pro power supply (ADP-300FR).
    A couple of weeks ago, I've picked up a PS4 Pro (CUH-7216B) from one of the local flee markets. According to the seller, it has a "no power" issue and the PSU is most likely faulty. Based on the cracks on the housing, it was probably dropped.
    Tried it at home and sure enough, it had a "no power" issue. (Pressing either the power or eject buttons had no effect).
    I took out the PSU and opened it. Immediately noticed that both transformers (marked as "T1" and "T2") are damaged. Their legs on the low voltage side are broken. (Looks like fall damage to me) Some of the pads where the legs are soldered are slightly lifted. (One pad is missing but that's a "no connect") I saw no burned component or anything else that was out of place.
    Talked with several people who repair PS4 Pros and found one who was willing to sell these transformers to me. He took them out of a ADP-300CR PSU but both PSUs use these 2 transformers according to him and this seems to be right.
    Soldered in both new transformers and after reassembly, the PS4 pro finally showed the first sign of life. After pressing either the eject or power button, I can hear a beep and the blue light comes up for like 2 second and it goes off (without a second beep!). Pressing either buttons again results in nothing. I have to unplug it for a couple of seconds and plug it back in order to reproduce the previous behavior.
    Took out of the PSU again to make some measurements and came to the following:
    I have 5v standby and its stable. As soon as I try to turn on the the 12v line by connecting "5VSB" and "ACDC_STBY" (I have soldered two cables connected to a switch so I dont have to short them using a tweezer), the whole PSU turns off and remains off until I unplug it and plug it back. It's basically the same behavior that the PS4 produces so I came to a conclusion that its a PSU problem.
    Measurements on the small connector (when "5VSB" and "ACDC_STBY" are NOT connected)
    ACIN_DET: 4.8V
    ACDC_STBY: 0V
    GND: 0V
    5VSB: 4.83V
    When they are connected, both "5VSB" and "ACIN_DET" falls under 1V and keeps decreasing. (The PSU seems to shut down)
    Since then:
    -I have unsoldered and tested every single through-hole MOSFET (Q3, Q4, Q6, Q102, Q101) (and a diode: D11) and all of them tested okay (I'm using a cheap component tester from aliexpres).
    -Checked the through-hole resistors (R5, R103) and all of them are okay (AFAIK the big one acts as a fuse and all of them should have very low resistance. Both are 3 ohms in my case.)
    -Checked for shorts in obvious places (ICs, MOSFETs, capacitors, 12V, 5V connector) but found none.
    I could not find the schematics of this PSU (ADP-300FR) however someone made a schematics for ADP-240AR which has many things in common (including some of the ICs) so I have attached it.
    I've also found some YouTube videos where yet another PSU is explained (ADP-200ER) but I'm not sure if I'm allowed to link them here.
    Any help is much appreciated. I've already spent like 2 weeks trying to figure out the issue and it's driving me insane
    • 31051
    Re: PS4 pro PSU (ADP-300FR) shuts down when turning on 12V
    did you test it on a dummy load and not in the ps4?
    • Norrecito
      • Apr 2022
      • 40
      • Hungary
      I have tested the 12V line with a 12V ligthbulb but same result (didn't even lit for a second).
      Haven't tested the 5V line with any load just yet.
        • 31051
        maybe it wont run without a load on every voltage
        • Norrecito
          • Apr 2022
          • 40
          • Hungary
          Unfortunately this is not the case
          Every single tutorial I've found shows the 12V line working without putting any dummy load on it. All it requires is to connect the mentioned two pins on the small connector (which also supplies 5V).
            • 31051
            R112 underside, 1miliohm resistor to monitor current - where do those long tracks go and is the resistor and tracks o.k.?
            • Norrecito
              • Apr 2022
              • 40
              • Hungary
              First of all, thanks for taking your time to help me
              Measured R112 and it's 0.2 ohm.
              The big tracks from R112 go to the middle 2 legs of T2 through a "jumper" on the other side of the board. (I drew it on the attached picture as well as another jumper that leads to a different section).
              The tracks are not damaged (verified with my multimeter).
              • Norrecito
                • Apr 2022
                • 40
                • Hungary
                Apologies, I've just realized that I have misunderstood your question.
                You meant the small tracks going from each pad of R112.
                The first one (farthest from the 12V connector) goes to R155 (280 ohm resistor) then through a zero ohm resistor, goes to the 3rd leg of IC151 (DNP012AH)
                The second track goes to D135 and ZD123 and the 12th leg of IC151.
                Both tracks are undamaged.
                  • 31051
                  thats the overload sensing - so thats a good area to be inspecting
                  • Norrecito
                    • Apr 2022
                    • 40
                    • Hungary
                    Okay, I will check that section under a microscope tonight.
                    In the meantime, I have to correct myself:
                    The second track goes to the 4th leg of IC151 from the mentioned diodes through a 10 ohm resistor. The 12th leg iof that IC s GND
                    • lotas
                      • Jan 2016
                      • 4620
                      • Russia
                      You checked that the PFC works for you, when you turn on 12v, the voltage on the large capacitors should increase by about DC 400v. If the PFC does not work, then the protection will work and the power supply will turn off completely.
                      • Norrecito
                        • Apr 2022
                        • 40
                        • Hungary
                        Yes, I wish I could test this but all 3 multimeters I have at home could only measure up to DC 300v Even with the PFC turned off (when the PSU is only running in standby), those caps are over 300v.
                        I might be able to borrow a multimeter that measures up to DC 1000v and test this.
                        • Norrecito
                          • Apr 2022
                          • 40
                          • Hungary
                          Okay I have borrowed a multimer and made some measurements on the high voltage capacitors.
                          When the PSU is running in standby (= no pins on the small connector are connected), the big caps have 317V.
                          After trying to turn on the PSU (by connecting the pins), it stays at 317V...so either the PFC is not working or it is just not turned on in the first place?
                          • lotas
                            • Jan 2016
                            • 4620
                            • Russia
                            Well, if the power does not rise, then the PFC does not work, there may be a microcrack on the board, look at large, power elements.
                            • Norrecito
                              • Apr 2022
                              • 40
                              • Hungary
                              I will.
                              The schematics I've attached (in my first post) has a PFC section, not identical (as it is for a different PS4 PSU) but similar. I might be able to use that to know what components should be checked.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Is that a scratch or a hair ? Is it cutting the traces ?
                                • Norrecito
                                  • Apr 2022
                                  • 40
                                  • Hungary
                                  Nope, it's from the brush I have used to clean the flux
                                  Scanned the board using my microscope and didn't find any micro cracks.
                                  Just seen a video where the PFC circuit was faulty and indeed, having a fault in the PFC section could cause the issue I currently have.
                                  The problem is I'm kind of lost regarding the PFC section.
                                  When comparing it to the schematics of the other PSU (the only schematics I currently have), it has a different IC with a different pinout. Even the huge coil (L1) has some differences and with this many small SMD components, it's hard to know what supposed to go where.
                                  The IC that drives the section is "NCP1612A3" (IC41). I've found the datasheet and attached it to this post.
                                  • Norrecito
                                    • Apr 2022
                                    • 40
                                    • Hungary
                                    There isn't much progress I can report. Still trying to figure out why the power is cut when I try to turn on the 12V.
                                    In standby mode, the PFC IC (IC41 - "NCP1612A3") has no power on the VCC leg. (0V) When trying to turn on 12V, it has something for a fraction of a second but the PSU turns off before I can measure it with the multimeter.
                                    Also measured the output of "T2" on the low voltage side to see whether I have 12V for a short time after trying to turn on the PSU but nope. Nothing there.
                                    I'm still not sure which IC cuts power and why. PFC is not running but I'm kind of stuck why. Would love to narrow the issue but I don't have the knowledge to do so.
                                    Made a note of the ICs on the board. Maybe someone will find this useful in the future:
                                    IC31 is "DAP046"
                                    IC32 is "DAP049"
                                    IC41 is "NCP1612A3"
                                    IC101 is "MP6922L"
                                    IC155 is "DNP012AH"
                                      • 31051
                                      check the pfc fet(s) & diode for shorts
                                      • Norrecito
                                        • Apr 2022
                                        • 40
                                        • Hungary
                                        I think I've finally found the problem!
                                        The PFC controller IC (IC41 - "NCP1612A3") is shorted.
                                        The following three legs of this IC are connected together (resistance is less than 5 ohms):
                                        7th - GND
                                        6th - DRV
                                        8th - pfcOK
                                        ...and I don't think they should be.
                                        I can buy this chip online but it will take at least a month to arrive.
                                        It's also glued down so I have to be extra carefull when removing it.
                                        I will report back with the results
                                        • JonnyS
                                          PS4 pro PSU ADP-300CR shuts down when turning on 12V
                                          by JonnyS
                                          I have a st_by voltage ane when i try to power on 12v line PSU shuts off
                                          i measure lot of components but i don't fins faulty piece ,
                                          when i try to power on 12v line voltage increasing to ~420v so it looks like PFC was working,
                                          Now i have no idea what i can do more to fix it and i will be very helpfully to help me in this case.
                                          10-10-2022, 10:34 AM
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
                                        • kotel studios
                                          FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                          by kotel studios
                                          Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                          Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                          I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                          Any ideas where to go next?
                                          02-23-2025, 11:47 AM
                                          KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                          by momaka
                                          For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                          http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                          I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                          What mostly drew me into buying it is its 2x PCI-E power connectors...
                                          03-29-2022, 11:34 PM
                                        • huzo
                                          HP Omen shuts down when loading OS
                                          by huzo
                                          The model is 15ec-1061nm
                                          Board number is DAG3EDMB8D0​
                                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                          10-29-2024, 12:05 AM
