Uni-t UTP3315TFL-II stuck at 40V laboratory power supply
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello
    My 2 years old unit is showing and outputing around 44.33v , values are real comparing with my tester... current seems to be fine if could be tested passing CC to CV as usual, rotating knov volt does not change values at all.... always arround 44 vol,
    PLEASE
    what to test?? in the pictures i have checked
    all is clean at 100%!! not blown components or traces of exploded caps or anything... most diodes are ok and transistors too i think..caps are good shape
    Marcelo J
    • 31169
    Re: Uni-t UTP3315TFL-II stuck at 40V laboratory power supply
    resolder all the front panel pots - they have hardly any solder on them!!
    • marce002
      • May 2018
      • 316
      • Argentine
      revised and they are almost perfect soldered...
      Marcelo J
      • marce002
        • May 2018
        • 316
        • Argentine
        it started to work fine again by itself, maybe the relay stucked or similar due to its sounds...tks for your help, and if you can confirm that a relay might have affected to generate this issue you are welcome..
        Marcelo J
        • redwire
          • 3912
          A stuck relay is not the problem, that does not cause the output voltage to get stuck high.
          I see many bad solder joints on the larger through-hole parts. Spend some time and resolder all of them.
          Some pretty dodgy parts used, this Vreg IC (pic) seems to have been found on the road in china and put to use.
          You can hit the unit with your hand, or tap the boards with a pen and see if a bad connection still exists. Because the fault will blow up whatever is connected to the power supply... it makes sense to actually troubleshoot and fix it before it kills something.
          • spiros.p
            • Dec 2020
            • 89
            • Greece
            agree with bad solder.i have cheap axiomet linear psu and was full of bad joints out from the box..to92 transistor bad soldered and not triger the relay.booth of them i have two.resolder booth chance all the c(r)apacitors and is working properly.
              by sam_sam_sam
              03-31-2024, 02:12 PM
            • navagator
              Hitachi Power Supply Unit Interchangeability
              by navagator
              I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
              Does anyone know if these 2 power supply boards are interchangeable?
              Thanks.
              01-08-2024, 07:53 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • Gjackson
              Air-conditioning unit power supply failing to power up
              by Gjackson
              Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
              01-08-2022, 09:24 AM
