A Shorted wirewound resistor?
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 661
    • samsara
    This resistor is from an ATX APFC PSU that connects bridge rectifier negative to primary capacitor negative
    I think that it's a current sensing resistor for the APFC
    Is it correct that it's color code indicates that it should be 0.47 ohms?
    I measured it to be around 0.08 oms
    The PSU blew up (visible arc flash) after problems with a powerstrip, but i got it working now after replacing the 10A fuse, rectifier, etc and removing/shorting the APFC diode locations and using a jumper in place of this PFC current sensing resistor
    I don't think that APFC likes being connected to powerstrips, as this is not the first time that i've come across this.
    Has anyone else come across a wirewound resistor that failed short instead of open?
    For the sake of completeness i attached extra photos of:
    the pink primary current sensing resistor, which tests in spec despite the wire being exposed (due to overheating?),
    and the small chopper transformer that had a piece of the top blown off (i stuck it back on with epoxy)
  • CapLeaker
    Leaking Member
    • 8178
    Re: A Shorted wirewound resistor?
    that's fine... you need a real good calibrated DMM and test leads to be that exact.
      • 31044
      thats a fuseable resistor, if it's not open circuit then it's fine
      • socketa
        Asbelowsoabove
        • Jun 2014
        • 661
        • samsara
        OK thanks
        i used a new aneng meter to check it
        and just out of interest ordered some new 0.15 ohm fuses, to check the meter against,
        and will post back here, if they arrive, to confirm if it does indeed have a lower resistance.
        Anyway, according to a schematic that i found, it looks to be a current sensing resistor for the APFC - so if the resistance varies too much from 0.47 ohms, then wouldn't that upset the APFC, and not be OK?
          • 31044
          thats too high for current sense i think - more likely it's inline with the gate of the fet
          • CapLeaker
            Leaking Member
            • 8178
            Before you go too crazy with this, you also have to understand the tolerances on the resistor and the tolerances on your new DMM.
            • reessi
              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
              by reessi
              Hello:
              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
              I started on the ACER:
              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
              10-29-2024, 11:31 AM
            • mikey5791
              Need help to replace burned resistor in 350w atx psu
              by mikey5791
              Hi to all forum members,
              Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
              The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
              Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
              Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
              12-26-2024, 04:55 AM
            • MidnightRoller
              Can a resistor lose resistance after hot air?
              by MidnightRoller
              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
              02-02-2022, 11:46 PM
            • artvandalai
              What resistor ohm will work better to repair this waterpik?
              by artvandalai
              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
              01-05-2025, 04:10 PM
            • modtool
              HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
              by modtool
              Hi to all,
              the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
              I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
              I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
              04-01-2025, 08:22 AM
