Aerocool Integrator 600W - ACP-I600HG - Low +5V SB
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    A mate gave me one of his old PCs, he said that he was having problems with the power button, so he had jumpered the green to ground on the PSU to make it work. When I finally got to it, it no longer seems to boot.
    Anyway, I stripped out the motherboard and PSU from the case, made a few basic tests, find the power button is fine, and all voltages seem to be ok-ish (3.30, 5.07, 12.20) except for the +5 SB, which is around 4.06V.
    The motherboard is GA-Z97P-D3, and seems to boot ok with another PSU, but the original PSU and the motherboard have the 8-pin CPU power connector. When I got it to boot with another PSU, that PSU only has a 4-pin CPU connector. Does the motherboard need to have an 8-pin connector? Maybe if overclocking? He might have been doing that, I need to ask him. The motherboard manual doesn't mention anything in this regard.
    So getting back to the +5V SB, are these power supplies worth delving into to try and repair? And is the 4-odd volts on that likely to be why it's not booting, is that too low?
  • lotas
    • Jan 2016
    • 4661
    • Russia
    Re: Aerocool Integrator 600W - ACP-I600HG - Low +5V SB
    Rather, it is necessary to replace the electrolytic capacitor in the + 5v SB power supply.
    • tmcw
      • Oct 2010
      • 382
      • Ireland
      Thanks, yes, it looks like it, when I cracked open the power supply, I found 2 1000uF/16V caps that are bulging on top. I haven't delved further to see if they are part of the +5V SB circuit yet though.
      There are a few other 1000uF/10v caps that are the same brand, so I might change them as well.
      • glovecaps
        by glovecaps
        11-25-2024, 04:23 PM
      • Docus
        Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
        by Docus
        Hi everyone 😀,
        I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
        To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
        Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
        1. I already own the exact same model, but its plastic chassis is badly damaged.
        06-10-2025, 04:24 PM
      • Archimedes
        HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
        by Archimedes
        Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
        Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
        Fans are spinning. Blindly could install windows11 and got the device manager...
        07-30-2024, 05:14 PM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
