Xbox 360 S adapter - 240v to 110v
  • anupkg1985
    • Sep 2020
    • 180
    I have got a xbox 360 console from India where it has an adapter designed to work with 200v-240v (135 watts) and has o/p voltages of 5v 1A standby and 12v 10A as operating voltage. Is there any way to modify the same to work on 110v in USA?
    • 31044
    Re: xbox 360 adapter - 240v to 110v
    have you opened it?
    it may just need a bigger fuse.
    • anupkg1985
      • Sep 2020
      • 180
      Please find the attached pictures. I see most of the caps on primary side are rated for 420v. Do I need to replace them?
        • 31044
        the caps are fine,
        the fuse may need to be uprated, but i'm not sure if it has a PFC circuit and how it would react.
        did you try it?
        • anupkg1985
          • Sep 2020
          • 180
          Yes it has pfc circuit and I'm getting only 1.2v on the secondary which I think won't be enough.
          • CapLeaker
            Leaking Member
            • 8179
            What do you get on the main filter cap? And that 1.2 V is on the 5V rail nothing plugged in?
            • anupkg1985
              • Sep 2020
              • 180
              Its 172v on main cap and 1.2v on 5v rail on the secondary side, nothing plugged in.
              • anupkg1985
                • Sep 2020
                • 180
                No one has got any experience on this???
                • R_J
                  • 9549
                  The circuit was not designed to operate with an input of 110vac. It won't work unless you redesign the primary circuit for both the standby and main power supply section.
                  Just get a step-up adaptor for 110~220v, 200watt or replace the power supply with a north American one.
                  • anupkg1985
                    • Sep 2020
                    • 180
                    How about adding the voltage doubler circuit before the rectifier or in place od rectifier bridge? Will that work?
                      • 31044
                      maybe if you had a 120v model to compare against, it's just component differences?
                      • CapLeaker
                        Leaking Member
                        • 8179
                        Probably easier using a step up transformer.
                        What is that 7 legged IC on pic 1, almost center on the bottom?
                        • anupkg1985
                          • Sep 2020
                          • 180
                          It's IC TNY276PN, I believe its for 5v standby voltage control. I'm getting 4.8v on pin 2 and 1.2v on pin1 of it.
                            • 31044
                            there must be good internal pictures of these things,
                            all the CB radio guys where converting them to output 13.8v a few years ago.
                            • anupkg1985
                              • Sep 2020
                              • 180
                              Can somebody provide schematics for the xbox 360 ps ?
                              • CapLeaker
                                Leaking Member
                                • 8179
                                Correct. That is the 5V standby, always on. Looking at the datasheet, the voltage you are measuring is below the min values. That is number one that needs fixing. After that you have to figure out if the PFC would work on 120V.
                                That's why I am saying it would be easier to find a used / aftermarket PSU or an transformer.
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  Maybe it would be feasible to use the device in a location where you have access to a 230v outlet like you use for high powered devices in the US?
                                  If not I'd just not bother with it and just use the transformer instead, easy solution...
                                  • anupkg1985
                                    • Sep 2020
                                    • 180
                                    I have already bought the 110V adapter for xbox however I'm just trying to modify this to work with 110v out of my curiosity. Most of the SMPS now days work on the range of 87v-240v input but this one is specifically designed to work with 240v so wanted under stand the components which contributes for this.
                                    As CapLeaker mentioned in the post above, it's the IC TNY276PN which is not working somehow and not producing the stb 5v. But not sure where should I start? I'm not a electronics engineer, I work as software engineer but this is my hobby so want to explore more.
                                    https://pdf1.alldatasheet.com/datash.../TNY276PN.html
                                    • anupkg1985
                                      • Sep 2020
                                      • 180
                                      What will happen if I replace the bridge rectifier with the voltage doubler circuit as shows in this diagram - https://www.homemade-circuits.com/wp...compressed.jpg
                                      Will that work / smoke / burn / damage?
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        Voltage doubler circuits require two bulk filtering capacitors, you only have one...
                                        Besides the last component to have a problem with low line voltage should be the TNY276PN
                                        It is literally designed to be a "keep it simple stupid" voltage controller accepting full range 85-265VAC.
                                        See the implementation example on page 8 of the datasheet...
                                        • Caimano
                                          HP 250 G7 runs slow and battery charge is disabled when adapter is inserted
                                          by Caimano
                                          HP 250 G7 with i3 8130U, MB EPK50 LA-G07EP REV 2.0 , PN L65699-601, Windows 10
                                          Laptop works perfectly when on battery and battery is charged correctly when laptop is off.
                                          Problem is that when adapter is inserted cpu clock is limited (visible in Task Mgr) and performance drops. Also battery charging is disabled when adapter is used and computer is on. As soon as computer is turned off battery charging starts.
                                          Tried bios update through Windows from version F38 to F42 . Same problem
                                          Reinstalled windows same problem.
                                          I tried 2 different...
                                          11-07-2022, 03:22 PM
                                        • Stevedb
                                          Boardview xbox 360 , xbox fat , xbox one x and xbox one s
                                          by Stevedb
                                          Hi all
                                          I will share the boardviews i found internet from the xbox 360 , xbox fat and xbox one x and xbox one s
                                          Pasw netcomchetumal.
                                          Enjoy it.
                                          Greetings Steve
                                          From Belgium...
                                          04-04-2023, 12:42 AM
                                        • TMTGTR
                                          An Xbox One PSU Odyssey
                                          by TMTGTR
                                          Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                          =>Background:
                                          I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                          06-17-2022, 05:40 PM
                                        • Unspun01
                                          XBOX One no power, random.
                                          by Unspun01
                                          XBOX One original, not XBOX One S. Has problems turning on.
                                          Power supply is good. Touch panel is good. Both work in another xbox.
                                          HDMI and USB ports are fine.
                                          The last time this XBOX turned on, it had an ERROR 102 so I know it can turn on, and I know it may have a hard drive issue. But the power issue is driving me nuts.
                                          When power supply is plugged into xbox, there is no response from the XBOX. Cannot power on, or eject. No lights. no sounds, not even a fan twitch. Power supply LED remains orange.
                                          Voltages are measured all over...
                                          03-24-2020, 01:19 PM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
