A question about PWM IC's
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: A question about PWM IC's
    Originally posted by Crystaleyes
    Hi.
    Excuse the delay.
    I lifted a leg of the resistor and had a poke around measuring in both DC and AC for any ripple.
    There's no working scope here so the testing was done with the DMM and revealed nothing on the DC although did appear to show some AC ripple when measuring across the filter caps and transformer primary.
    It shouldn't be the caps as they are new replacements
    If I'm honest, I'm not really sure what signs I should be looking for other than low voltages, but perhaps someone can enlighten me?
    Did your replace the IC? I am going by your data sheets typical circuit. Is this what you have? The bridge rectifier is the 4 diodes group diamond shape. If the resistor leg is lifted to Vin and you measure the capacitor going to the bridge rectifier at capacitor pin1 you should have a DC voltage. If no DC voltage on the capacitor check pins 1 to pins3 of the bridge rectifier for you AC input Voltage. If you have the AC Voltage then check the diodes of the rectifier.
    Again, I am going by the typical circuit in your data sheet. If you are measuring with a DVDM then on the AC scale you might pick up the ripple which should be a sawtooth wave form as AC Voltage. This sawtooth waveform rides on top of the DC which is normal without the IC connected. When the IC is connected an working you should have a pulsating DC square wave. Depending on the frequency and the meter you are using you may or may not be able to read it with that meter.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Here is the front end of your sample circuit. This is the first half cycle of what happens with the AC voltage. I showed the current flow of what happens in the diodes of the bridge rectifier. When the bottom half of the cycle of AC voltage happens, the top voltage goes negative with respect to ground. Then it will proceed through the other two diodes of the bridge rectifier. That then in one cycle. In the US this happens 60 times a second. In England I believe it is 50 times a sec. The diodes are just one-way switches. The line on the diode forms a letter K which stands of Cathode. A cathode needs a negative voltage to work. So that means the back end of the blackened arrow is a Anode. A anode will need a positive voltage to work. Each silicon diode drops 0.7 Volts DC in order to forward bias the diode so current will flow.
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        The IC is due to arrive on Wednesday, and as for the circuit, it has a standard single piece, four pin bridge rectifier, which is testing fine with or without the IC connected, as are the two filter caps.
        I also have one of those multi-component testers and the primary all seems fine (MOV, NTC, FET, caps, diodes, resistors etc.) except that the voltage across the transformer primary is just a constant DC. No frequency, and the DMM I have is good enough to detect that.
        I'm eager to see how changing the IC will affect things.
        • R_J
          • 9583
          Is this the same power supply that had the blown source resistor? https://www.badcaps.net/forum/showthread.php?t=105220
          If it is, then that was why the ic was damaged internally.
          You won't measure any "ripple" on the main capacitors in the state is in now. The main filter caps will charge and without any load, they will not discharge, so you may want to discharge them with a large resistor. at least check the voltage across them before working on the circuit to make sure they are discharged.
          Once the ic is installed, the main dc voltage will not change that much, likely just be slightly lower dc value.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            That is what you are looking for a constant DC with "no" IC in place. It is so much easier with a Oscilloscope. So with the DC voltage on the transformer it tell you that the bridge circuit and everything that comes before is working. One can actually figure out what DC voltage will be on the Primary. One would take the peak to peak voltage and divide it in half then by 0.668. I am going on a 40 year old memory on the .0.668 I believe that to be very close. That would be called average power which is the DC equivalent of a sinusoidal waveform of 60 Hz better know as 60 cycles per second.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              I am thinking the path for the discharge and recharge are though the diode bridge as the AC voltage becomes less the cap voltage becomes less because the cap has access to ground through the bridge diodes. The cap will become a supply voltage when the bridge voltage becomes less on the down part of each half wave of the AC voltage. So it would be worth it for someone to set up a bridge rectifier an capacitor to see with a scope if there is a discharge. It has been a while since I did any of this work and would say not to take anyone's work for it but, to actually try it in a circuit.
              One could first bypass the FET with a diode and put the transformer into play. The resistor on the bottom of the FET should protect the current draw. If this was OK then one could bias the FET on to see if that works.
              • R_J
                • 9583
                Yes your right the ripple will not appear without a load because the capacitor needs a path to discharge and recharge.
                This would result in the resistor (0.12Ω) blowing open. The fet must be driven by high frequency drive signal, Bypassing the fet with a diode? this would cause excessive current through the primary and at a minimum blow the main fuse. You do not want the transformer in a dc circuit, it must be ac, and in this case it is designed for 20~60khz
                In the OP other thread, the problem was the mosfet shorted causing the source resistor to go open, when this happens the sense input to the ic which is connected to the mosfet source via R16 is subject to the full dc voltage, 165~350vdc, the ic can never handle this.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  There is not AC going through the transformer but, a pulsating DC waveform with a varying duty cycle. This is what the bridge rectifier is putting out DC.
                  The cap with bridge rectifier should not be at a greater voltage than what the designer had intended whether it is DC or a pulsating DC square wave. So when voltage is applied to its max at either DC or pulsating DC one has the same current going through the primary. If the designer did not allow for a steady state to happen then I would say he under design the circuit. Remember I am going by the sample circuit as yet I have not seen anything else posted in this thread. Looking at the other thread you referred too I see no schematic in that thread either.
                  Also, understand that the DC voltage has a primary winding in it and a resistor under the FET. I do not know what the FET value is but, when it conducts it will have a very low resistance. Perhaps the bottom resistor is not correct and allowing to much current to flow. Perhaps there needed to be another resistor in the FET circuit to make a voltage divider for the sense. Or it may need a resistor above the FET to lower the current. I do not know as I do not have the valves and schematic to the real circuit.
                  • R_J
                    • 9583
                    The cap with bridge rectifier should not be at a greater voltage that what the designer had intended whether it is DC or a pulsating DC square wave. So when voltage is applied to its max at either DC or pulsating DC one have the same current going through the primary. If the designer did not allow for a steady state to happen then I would he under design the circuit. Remember I am going by the sample circuit as yet I have not seen anything else posted in this thread.
                    You must have a smps around , try bypassing the fet with a diode like you suggest.
                    The difference between dc resistance and ac inductance is what you are overlooking. The DC resistance of the primary is likely about 2~10Ω, apply (using N.A. line input values) 165vdc, what would be the current?
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      No actually I have none of that. I do not like working on these things. Instead I enjoy doing art. AC inductance you will have your apparent power, real power. Real power is resistive power. Apparent is power is figured by Xc. Xl and resistance. It is figured in a sinusoidal wave frequency. Real power is actually what is going through the circuit. However, we have pulsating DC. So when the circuit gets turned on it is full on not a gradual sign wave this will affect the circuit differently. The moment the voltage is applied the transformer it will see all voltage. The current will lag behind by 90 degrees in a sinusoidal waveform. With pulsating DC with a varying duty cycle I would not begin to try and figure that one. I am sure there are equations for this an long explanation. I do not wish to go into that as I have no desire to be an electrical/electronic engineer. Still the current will see the resistance of the coil and the resistance of the FET and the resistance of the bottom resistor. The real current will be resistance and this will give the real power. Phase shifting the Voltage as oppose to Current effects only the apparent power. The apparent power will always be greater than the real power.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        So your telling me that the peak to peak voltage on the AC line is 486 Volts? We do not know what the resistance of the primary is. We do not know what the value of the FET is. We do not know what the value of the bottom resistor is. If you give me these valves I can figure out the current in the circuit at 165 Volt DC I can tell you whether the FET can handle that current. If it can not handle that current the circuit needs a FET capable of doing it. If none go up that far then the circuit needs to be re-design to accommodate a lower current. In this way one does not blow up the circuit when something goes bad.
                        • Crystaleyes
                          • Sep 2021
                          • 493
                          • Brazil
                          #32
                          Hi fellas.
                          That was an informative few posts. Thanks.
                          As for the values, the original source resistor is unknown however looking at almost identical boards with the exact same output values, then I believe it to be 0.12Ω. The transformer has two primaries which both measure super low 0.1 ish and the original fet was a 12 60 of some sort (don't remember right now).
                          Given the question around the source resistor, would it not be worth first switching it on with the gate disconnected, in order to check that the chip output is fluctuating correctly?
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            Hi fellas.
                            I would go by what R_J is telling you about the FET and DC voltage. I read through the chips information and they do all sorts of things to protect from over current and overvoltage. R_J is an active technician doing repairs and should know how these things work. My intention is not to take that away from him. My intention is to provide you with what basic theory of electronics is. With that I still believe that the mosfet in the primary winding circuit needs to handle the full DC current running through it. This is a condition that the designers are trying to avoid with all the over voltage and current protection built with-in the chip. However, we know that in your case this did not work. When Engineers I have worked with have come across such a problem they go back to the circuit and find the cause and then make the circuit more robust so the same condition is not done again.
                            • R_J
                              • 9583
                              How do you come up with this? The line voltage in N.A. is 120vac, with a full wave bridge and a filter capacitor the DC voltage across the filter capacitor is approximately 165VDC. The primary DC resistance was just a guess, I went and checked one I have and it measured about 1Ω.
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                Hi fellas.
                                I you lift up one leg of the resistor connected to the FET which I believe you said was the source leg and measure it then you will know it's values. The reason for the two primaries is explained in your data sheet. When working on a circuit it is important to know exactly what you are working on. To know the schematic and the components and how they interact with one another. This is a key to successfully repairing electronic so they do not come in your door more than once. I trust R_J's experience and I believe he will finish up with you in working on this circuit. If you have greater desire of the actual theory behind circuit I would suggest that you lean toward becoming an engineer. In this case it would be best to learn this in a school.
                                • R_J
                                  • 9583
                                  Hi fellas.
                                  There is only one primary winding, that is the one connected between the main DC voltage and the mosfet drain. The other winding on the primary side is the feedback winding, it will supply the ic' vcc voltage (via a diode and cap) to keep the ic working after startup.
                                  I would not disconnect the mosfet gate to check the ic output. The ic needs to have the feedback vcc voltage as well as the source voltage to operate otherwise it will go into protection.
                                  If you are going to check the ic output you need an ISOLATED scope, so the scope must be battery operated, If the scope is line powered you need an isolation transformer to connect the power supply to. If you don't do this, as soon as you connect the scope ground you will blow the power supply main fuse and usually the bridge rectifier as well.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    You simply can not get more power out of something that you put into it.125VAC bridge rectifier will never put out 165VDC. I do not see a voltage multiplier on the input. We have to ask is the 120VAC a RMS voltage or a Peak to Peak voltage. RMS voltage is figured from Peak to Peak voltage by divided the Peak to Peak voltage in half and then multiplying by 0.707. Average voltage which is the DC equivalent can be figured by dividing the Peak to Peak voltage in half and then multiplying by 0.678. And through algebra one can find the correlation between the two.
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      How is the ground of the primary winding circuit being risen above earth ground? Earth ground is usually connected to the neutral line at the fuse box and it is the ground of a plug.
                                      • R_J
                                        • 9583
                                        Do you have a bridge rectifier and a electrolytic cap of around 10~100µf with a voltage rating of 200vdc. connect them up and check the voltage. without the filter cap the raw dc output will be around 108vdc
                                        • R_J
                                          • 9583
                                          I give up!
                                          • ductranvinh
                                            Graphics card repair, Basic Measurements
                                            by ductranvinh
                                            Hi everyone!
                                            The preface to this article is for those who are new to graphics card repair. I'm not as talented as mods or admins either.
                                            But in this article, I will guide you through the most basic things to quickly recognize the disease in each block, so that you can make a foundation as well as form a habit.
                                            Note! This article may or may not be true.
                                            Measurement: (must have boardview of course)
                                            Adjust the impedance scale
                                            12v block
                                            Measure the 12v fuses, see if they burn out.
                                            If the fuse blows, the risk of burning the pcb is...
                                            06-29-2022, 05:12 PM
                                            Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                            by sam_sam_sam
                                            I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                            I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                            I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                            02-04-2025, 08:08 PM
                                          • YellowJacket
                                            Dell P2416DB - no picture
                                            by YellowJacket
                                            Hi friends,
                                            I am here for asking for a little help with this monitor. It reacts to pressing the power button, but the only thing I get is working back light, with no picture. I was measuring all power voltages, you can see them in attached picture. There is 3.3V on the SPI ROM chip, and I can see healthy-looking communication on it ( pin 1 is changing ) after powering on. I can see nice clock signal on both crystals. I am even able to measure some low voltage data signals on LDVDS cable. So I believe, my issue in on the panel itself. I proved it by measuring VGH1 signal on a test...
                                            01-16-2024, 07:45 AM
                                          • DynaxSC
                                            Extreme High Current & Low Voltage Short Killer ??
                                            by DynaxSC
                                            Hi Folks
                                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                            After taking off the socket, the shorts dissappear again.
                                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                            10-15-2024, 10:13 AM
                                            MTFC2GMDEA-0MWT MTFC4GLDEA-0MWT MTFC4GMDEA-1MWT MTFC8GLDEA-1MWT MTFC16GJDEC-2MWT MTFC32GJDED-3MWT MTFC64GJDDN-3MWT Datasheet
                                            Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
                                            The nonvolatile...
                                            10-07-2024, 04:55 AM
