Graphics card repair, Basic Measurements
  • ductranvinh
    • Dec 2021
    • 136
    • Republic of Vietnam
    Hi everyone!
    The preface to this article is for those who are new to graphics card repair. I'm not as talented as mods or admins either.
    But in this article, I will guide you through the most basic things to quickly recognize the disease in each block, so that you can make a foundation as well as form a habit.
    Note! This article may or may not be true.
    Measurement: (must have boardview of course)
    Adjust the impedance scale
    12v block
    Measure the 12v fuses, see if they burn out.
    If the fuse blows, the risk of burning the pcb is quite high. When the PCB is burnt, the whole circuit can short 12v all the rails on the pcb.
    If the pcb is still ok and does not burn, the possibility of a short fet is high.
    5v block
    Measure 5v coil impedance to ground
    If the coil does not have a voltage of 5v, the coil must be removed to handle voltage loss first or voltage loss later.
    3.3v block
    Measure the impedance of pin 8 on the motherboard contacts
    If short, 100% gpu is dead
    1.8v block (Required voltage is always available)
    Measure coil impedance 1.8v
    Usually not short. The common disease is no voltage.
    Block 1.01v (or vboot 1.1v for 10th generation cards and below)
    Usually this block is not short
    GPU block
    Usually this block has very low internal resistance. So you don't need to care about this block very much. Because when measuring block 3.3v can ignore this block
    vRam block
    Usually this block has a low internal resistance of 3.5 - 4.7ohm. If internal returns to 0, then surely 1 or 1 pair of ram is dead.
    ** This line voltage theory is 1.5 even d5 or d6. In fact, when operating, the voltage ranges from 1.3 to 1.4v.
    Focus and work quickly. You only need to measure 12v and 3.3v blocks. unit
    Loss of voltage in one of these blocks has about 90% chance of causing card not detected error and 10% causing "!" legendary
    PC work for schemaltic:
    Mainboard: Gigabyte Z68XP-UD4
    CPU: I3-3240
    Ram: 16Gb
    Graphic Card: GTX 1050Ti zotac 4Gb Mini
    SSD: 120Gb
    HDD: 2Tb
  • bimole
    Weird behavior on 3.3V rail of a CORSAIR CX600
    by bimole
    A colleague gave me an apparently ill CORSAIR CX600.
    He told me that he heard a banging noise, and smelt the magic smoke.
    After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
    I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
    It's another story on the 3.3V rail...
    I have some devices to test deeply PSUs (scope, AC source, electronic load)...
    02-13-2025, 04:49 AM
  • sheffieldyorky
    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
    by sheffieldyorky
    Hey there people
    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
    This is what I tried, but not in any order.
    Google
    YouTube
    BIOS
    Command Prompt (administrator privileges)
    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
    10-25-2025, 02:22 AM
  • angeloavv
    ASRock H81M-DG4 power cycles and glitches - sometimes POSTs sometimes not
    by angeloavv
    Hello everyone! This is my first post and this motherboard is driving me crazy because everything looks so non-trivial that I don't know where to start investigating. During these days I believe I watched half of the YouTube videos trying to understand how to troubleshoot power cycles but at the same time, I'm confused because my motherboard doesn't always do that and sometimes completes the POST for a few seconds: the right amount of time to freeze, show glitches on the screen, and then reset itself.
    Let me give you a bit more context to understand why and how we got here.
    12-26-2023, 03:32 PM
  • hs5424
    Dynacord powermate 1600 block diagram.
    by hs5424
    Hi All,
    I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
    The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
    07-31-2025, 01:35 PM
  • GTAVC16
    Alienware 18, Nvidia GTX 880m presumably shorted
    by GTAVC16
    Hi guys!
    I'm in need of some support so I can try to fix my laptop/gpu.
    While I am a cerified automotive mechatronic, I have only basic understanding of electronics repair and identification.
    I'd like to identify the issue and replace the specific component myself to learn about electronics and expand my skills a bit.
    No better time than now, when my laptop, Alienware 18 from 2013, shut down when playing and refused to start again.
    I know about electric diagnostics in and about cars, but I've never dabbled with electronics.
    However, I know...
    08-20-2023, 05:39 AM
