Missing Component Values on a Pectlight TX1775DH PSU
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    I was given a Chinese lighting SMPS to have a look at.
    It's only a small thing with a single 24v 8.3A output, coming off a 127v mains input.
    It came with a blown fuse and someone had already changed the filter caps and the switching Mosfet Source resistor, and it is these values which I am wondering how best to work out.
    The FET is a FQPF12N80C N-Channel with the Source resistor connecting straight to ground.
    The original resistor had been replaced with two piggy-backed 0.33Ω which measures around 0.18Ω on my tester. I am still learning with SMPS's, but this seems way too low.
    Do I need to calculate this resistor for the 3.0A input rating, or does it need to be able to deal with the 8.3A output current?
    As for the caps, they had been replaced with 100uF 450v which were physically oversized, so sat wonky.
    What calculation can I use to find a suitable value for these?
    Any help would be greatly appreciated.
    Attachhing some photos...
    • 31262
    Re: Missing Component Values on a Pectlight TX1775DH PSU
    you should have rejected the job,
    nothing worse than something somebody else has fucked with!
    the resistor is a mystery,
    the fet probably originally shorted and fed mains to the driver circuit
    but you dont know because somebody has been in already!
    • R_J
      • Jun 2012
      • 9610
      I would have rejected the repair as well, but the source resistor could be close to 0.15Ω. BUT, when the mosfet shorts and the source resistor opens, the drive ic is usually bad as well. there should be a small resistor (R16) connecting the mosfet source pin to the CS pin of the ic. and when the source resistor opens, 160+ volts is applied to the ic CS pin. damaging it. ZD2 could be damaged as well. Sell them a new one
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        Thanks for the replies, but I'm gonna try and get it working, it's not actually a paid job, more of a favour for a friend who runs a small lighting company
        SMPS repair is something which I really want to crack so at the very least I'll be learning more than I know now..
        It's not exactly the most complex of supplies and I can literally pull and test every component other than the ic.
        Have checked every diode on the board, with no failures.
        Three small polyester caps read lower than their rating however, and the suppression cap is also very low.
        The chip is available online so I think I'll give it a go and see how far I get?
        Maybe I'll contact the company and see if they can't give the missing values?
        Nothing to lose....
        It's not working now, is it?
        • Crystaleyes
          • Sep 2021
          • 493
          • Brazil
          Think I may have found the source resistor value...
          This photo is taken from a similar rating PSU and seems to show a 0.12Ω resistor.
          The only real difference between the two PSU's is that this one has no smd components
            • Jul 2011
            • 6070
            I would highly recommend that when you think that you might have it repaired
            I would use an incandescent light ( at least 100 watt ) bulb instead of the fuse and see if the light bulb light’s very brightly and is continuously ( it should dim down considerably from when you first power it up ) then you might still have an issue with the circuit board or if does not light at all then you have another issue
            • Crystaleyes
              • Sep 2021
              • 493
              • Brazil
              Thanks for the advice.
              For sure it'll be switched on through a lamp.
              Been too busy to even look at it these last few days, yet I'm suspecting that the OB2269 PWM controller has failed.
              I'll obviously test the smd 431 and the opto-coupler first, so let's see?
              • badcap111
                Xiaomi mi 9T missing resistor
                by badcap111
                Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
                I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
                Is...
                08-07-2023, 10:42 AM
              • spleenharvester
                Ugreen HDMI splitter missing a pulldown resistor
                by spleenharvester
                Odd one I've found. This splitter likes to cut out - on my Xbox Series S the display/audio would randomly go to black for a few seconds - on my PC the monitor would flicker several times before eventually staying on. A few others have reported similar issues. Couldn't be bothered returning it for the sake of £8.
                I pulled it apart and found it is driven by a Texas TS3DV642 mux/demux. There appears to be a missing pulldown resistor on the HPD line, it is just left floating. Adding a 100K pulldown to ground fixes the flickering.
                (Not that this is worth the hassle for an...
                09-15-2025, 11:23 AM
              • skdsp
                Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
                by skdsp
                I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
                Attached is the photo.
                Thank you!
                09-27-2025, 09:05 PM
              • liquidzorch
                Missing resistor on BQ ILIM pin. DA0P5JMB6D0
                by liquidzorch
                Hello. I can't find the schematics anywhere for this motherboard, does anyone have one, and can give me the resistor value for the BQ728H missing in pic below? I already read the dadsheet, and this resistor value is calculated, so I can't just go with whats in the "typical" diagram.
                On a second note, could this resistor cause it to only boot with the battery and not the charger? It boots fine with a charged battery, but will not turn on with the charger (nor charge). The 19v does not get past the first mosfet, it recieves pulses to turn on, but something is preventing it....
                12-18-2023, 01:56 PM
              • briztech
                identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF
                by briztech
                Hi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
                07-25-2024, 06:18 AM
