Cyberpower CP900EPFCLCD - F03 Error
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #61
    Re: Cyberpower CP900EPFCLCD - F03 Error
    Those readings do not sound completely out of the ordinary.
    What about the PCB right now with the transformer taken out, what do you read?
    Still got any low readings? If so that points to something else being in short.
    • Shinjinkun
      • Mar 2022
      • 35
      • Spain
      #62
      Yes, that's what I thought. I thought maybe the transformer was responsible for the short, but it doesn't look like it.
      I haven't connected the PCB after removing the transformer, as I wasn't sure if I could do it or not... should I?
      I am still concerned with the two components which we didn't have the value, the capacitor and the zener diode... I am using a 470pF smd capacitor and a 39V zener... could it have some relation with the short, or shouldn't have really anything to do with it?
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        #63
        Those components will not cause a short.
        I would not power up without the transformer.
        But do some ohm checks where the transformer windings was previously and post back the results.
        • Shinjinkun
          • Mar 2022
          • 35
          • Spain
          #64
          Where should I make the measures? I attached the pictures of the pcb after removing the transformer to point it out.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            #65
            You seemed to have identified the transformers windings in your post #60.
            Just measure the same way on the PCB, and see what you have.
            An example: the primary winding needs to measure open on the board now.
            Same for the secondary winding(s)
            • fmiku
              • Jun 2024
              • Hungary
              #66
              Hi guys,
              Anyone can help me out to repair the UPS ?
              I need to know the value of the 3 resistors or at least the operating voltage of the power supply (at the green arrow).
              Thanks,
              • unimatrix93
                TV backlight zener diode
                by unimatrix93
                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                The led strips has 9 6V leds.
                02-10-2025, 12:13 PM
                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                I bought this from an eBay seller but unfortunately they only had one
                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                I bought three of from them to also make battery packs with this output power limit in mind
                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                04-23-2025, 05:50 AM
              • Vincenzo2
                Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                by Vincenzo2
                My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                I put some pictures here to show that it is labeled "M7"....
                09-07-2023, 07:43 PM
              • hobostove
                Corsair RM1000e - Help identify 5VSB Zener diode
                by hobostove
                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                There's a 22ohm resistor that's melted and open, but it still has the bands.
                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                It looks like the diode connects the source and drain of a TNY284...
                03-27-2025, 02:25 PM
              • debidoobs
                Yamaha delay D1500, zener diode broken with no marking
                by debidoobs
                im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
                Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
                04-24-2024, 09:01 AM
