Purpose of -5V and -12V rails
  • phoenixlament
    • Aug 2009
    • 20
    -------------- Background Info.. (skip if you like) --------
    I recently found an abandoned low-end P4 computer with a generic power supply inside. The computer was able to boot properly. Suspecting power supply malfunction as a possible cause of the abandonment, I opened the PSU (Y2K YoungYear PS-IV 350-1, actually 250W) and discovered a leaky fuhjyyu and a burnt out resistor, adjacent to a mildy burnt patch on the pcb.
    I replaced the leaky fuhjyyu and the other identical fuhjyyu next to it with two working caps (can't remember brands) in an attempt to raise the +12V,-12V, and -5V rails which were registering at 11.12,-10.92,-4.27 volts respectively. All other rails are working within the acceptable +/- 5% range.
    After the two cap replacements, I'm getting 11.4/-11.08/-4.37 volts respectively. The improvement wasn't significant probably because of the burnt out resistor. I was unable to replace it because the color coding has burnt off and I don't have a schematic for the psu. However, the computer still boots as expected. (I plan to move the psu onto a P3 1ghz psu-less computer lying around)
    ----------------End background info --------------
    So question is: What is the purpose of the -5V and the -12V rails? Do they do anything at all these days?
  • bluto
    • Oct 2007
    • 560
    Re: Purpose of -5V and -12V rails
    For legacy stuff(not really doing much for you these days), specifically:
    -12 V: This voltage is used on some types of serial port circuits, whose amplifier circuits require both -12V and +12V. It is not needed on some newer systems, and even on older ones not very much is used, because the serial ports require little power. Most power supplies provide it for compatibility with older hardware, but usually with a current limit of less than 1 A.
    -5 V: A now archaic voltage, -5 V was used on some of the earliest PCs for floppy controllers and other circuits used by ISA bus cards. It is usually provided, in small quantity (generally less than 1A), for compatibility with older hardware. Some form factor power supplies such as the SFX no longer bother to supply it (systems using the SFX power supply are intended not to have ISA bus slots).
    http://www.pcguide.com/ref/power/sup...oltages-c.html
      • 31285
      wrong,
      it's used for balanced op-amps in high-end audio circuits.
      you wont be likely to see it used on the built-in shit, but high-end cards will probably use it.
      you can often remove it, but it will effect the sound quality.
      • Wizard
        • Mar 2008
        • 2296
        Atom ITX boards I use do need the -12V. That how I found out because of bad cap in PSU.
        Cheers, Wizard
        • phoenixlament
          • Aug 2009
          • 20
          Thanks for the info guys.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            The -5v rail was removed from the ATX spec as of ATX12V 1.3
            • japlytic
              • Oct 2005
              • 2086
              I wonder when the -12V would be removed from the ATX specification... but it is used in the PCI specification, but not by PCI Express slots.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                It is probably not so far off
                It took the PCI spec roughly 10 years to completely supersede ISA
                And the PCI Express bus was introduced in 2004...
                My bet is 2013
                • boxy
                  • Jun 2010
                  • 5
                  Originally posted by stj
                  wrong,
                  I'm suprised a high end sound card would use the noisy raw supplies from the main SMPSU. Maybe use +/-12V and then internally regulate it down with linear regs.
                  • Slakky
                    • Nov 2009
                    • 15
                    Yeah, I'd be interested to see what cards these are too. Even the old Lynx TWO got by on split 5V for balanced transmission, and running unfiltered SMPS voltage pretty much destroys your noise floor.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3113
                      How much ripple is too much? ATX spec for 3.3v and 5v on a computer psu is 50mv, 120mv for 12v and 200mv for -12v.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        -5v was power from some 16-bit IC chips.
                        Those chips are usually only found on ISA cards but some boards [talking P3 vintage] may have used the same chips directly on the mobo.
                        Some early MSI P4 vintage boards [maybe others too] continued using 16-bit LAN and/or sound chips directly on the mobo long after those chips should have been retired as a cheap-out method.
                        [Talking about the time of the Intel i845 chipset].
                        Those boards still need the -5v even though they have no ISA slots.
                        -12v is still used.
                        Standard PCI slots and some 32-bit chips use it.
                        Mann-Made Global Warming.
                        - Dr Seuss
                          • 31285
                          a lot of serial ports still use -12 because a charge-pump like a HIN202 costs a few cents more than the old '188 and '189 pair and it needs 4 decent ceramic caps too.
                          • Slakky
                            • Nov 2009
                            • 15
                            If you're talking about audio line driving applications, your dynamic range is 2V RMS absolute max, so 1mV of ripple is a 66dB noise floor, which you might find on the world's crappiest onboard audio. 200mV is hearing damage country.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              We are talking about motherboards, mobo PSUs and the ATX spec.
                              - Dr Seuss
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                I've seen a drawing [mobo schematic] that showed -12v being used as a ref voltage for something like the MCH or the chip that sets CPU voltage but I can't find the drawing to refresh my memory.
                                - Dr Seuss
                                • brethin
                                  • Dec 2008
                                  • 1907
                                  -12 for the ATX spec will never go away. Ok never is a long time but I dont think we will see it.
                                  • electomech-fixer
                                    First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                    by electomech-fixer
                                    I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                    I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                    09-15-2025, 01:42 AM
                                  • skwarszczow
                                    Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                                    by skwarszczow
                                    This is my first post on the forum
                                    I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                                    Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                                    Before completing the purchase, we decided to erase...
                                    03-23-2025, 06:04 PM
                                  • SarcasticOP
                                    General question about MacBook power rails for repair.
                                    by SarcasticOP
                                    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                    • PPBUS_G3H (12.6V-12.8V)
                                      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                    • PP3V42_G3H (3.42V)
                                      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                    • PPVRTC_G3H (3.3V)
                                      • This
                                    12-12-2024, 05:50 PM
                                  • Cemal Odabasioglu
                                    MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                    by Cemal Odabasioglu
                                    I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                    Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                    Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                    Observations...
                                    01-14-2025, 03:54 PM
                                  • dicky96
                                    Zotac GTX 260 burnt component - can anyone identify?
                                    by dicky96
                                    Hi guys
                                    This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
                                    This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
                                    Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
                                    I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
                                    The good phase...
                                    12-01-2021, 01:02 PM
