STR2A153 vs STR2A153D SMPS IC
  • dkneyle
    • Dec 2013
    • 445
    The device I want to replace does not have the 'D' suffix, but the replacement I have in my parts drawer does have the 'D'.
    I can't find any specific datasheet on the net for a 'D' variant. Do you reckon it's just slightly spec'd up and hence the designation: D?
    • Jul 2011
    • 6070
    Re: STR2A153 vs STR2A153D SMPS IC
    Here is the data sheet
    https://datasheetspdf.com/mobile/938...ken/STR2A153/1
    • dkneyle
      • Dec 2013
      • 445
      Yes, thanks, I had the datasheet. But it makes no mention of a 'D' variant, hence why I was asking around if anyone had any experience with this SMPS IC?
      In the repair I'm doing it is used in a Pioneer Receiver VSX-529. The IC is rated at about 35W output. It directly drives the switching circuit - no external mosfet. I gather it is used in an auxiliary supply which must power the logic circuits etc of the receiver?
      • R_J
        • Jun 2012
        • 9633
        On other versions the `D' stands for auto restart on OVP, TSD Operation
        • dkneyle
          • Dec 2013
          • 445
          Hi RJ,
          You might need to spell out those acronyms for me?
          And in terms of a SMPS, what does auto restart actually mean? If mains power was lost, and then came on again, I would have thought any SMPS would start up again. So I'm obviously missing something?
          • R_J
            • Jun 2012
            • 9633
            I am looking at the STRA3A200 datasheet
            − Overvoltage Protection (OVP) : Latched shutdown or
            auto-restart
            − Thermal Shutdown (TSD) : Latched shutdown or
            auto-restart with hysteresis
            • dkneyle
              • Dec 2013
              • 445
              Thanks RJ. I think that does explain it most likely. "Latched Shutdown" is abnormal condition keeping the SMPS switched off; auto-restart where it does exactly that after the condition is removed.
              • dkneyle
                Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                by dkneyle
                This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                02-01-2022, 02:08 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • abhishekkumar1902
                Huntkey HK340-72FP SMPS shut on load above 2 amps
                by abhishekkumar1902
                I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
                I have checked the following:
                1. All output caps are OK, and all output rails read correct voltages at no load
                2. All output diodes are OK
                3. NTC is ok
                4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
                5. No short in main switching MOSFET
                6. All other components...
                12-18-2022, 09:52 AM
              • madan1
                Mackie Th15 SMPS low Vout
                by madan1
                I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
                It is basically a smps with amp and some dsp.
                The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
                Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
                By the way, the ferrite core of L10 is broken,...
                02-16-2025, 04:15 PM
              • rewease
                Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                by rewease
                There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                09-17-2023, 12:53 AM
