Xilence 1200W. Keeps restarting
  • victorcas
    • Oct 2021
    • 12
    • España
    I have repaired a few PC PSUs before, but the problem has always been a broken Mosfet and blown capacitors fails. Now I am facing a PSU problem that I haven't seen before.
    I have a Xilence 1200 PSU that had 4 broken capacitors on the 5V and 3,3V lines, and a faulty mosfet driver (A6069H). After replacing these components, the PSU starts up and turns on the fan providing all the correct voltages at the output, but shuts down after a second. when the output is low again (capacitor discharge, I guess), the PSU starts up again and repeats the whole process.
    I think it has to be with some kind of overvoltage or overcurrent sensor, but I can't find the faulty component. I have also tried connecting a small 12V motor to the 12V output and I see that it keeps restarting but the motor turns (I guess I shouldn't try to connect an inductive load, but that's what I have...).
    I uploaded some pics with a red circle/square over the replaced components.
    I have no idea how to proceed. Any advice or hints would be appreciated. Thanks in advance!
    • Jul 2011
    • 6070
    Re: Xilence 1200W. Keeps restarting
    Look for a capacitor that is around 10 to 50uf or could be a little higher than that is close to the switching power supply regulator ic chip ( that you have replaced already A6069H) and replace it even if looks ok and see if it makes a difference or not
    There are some ATX switching power supply that require a load on either the 5 or 12 volt rail to work correctly so be aware of this as well use some automotive type head light bulbs would work better for this I done this myself
    Or you could have a rail that is pulling to much current
    Check with out power to board and see if you have a short on any of power supply rails with a ohm meter
    I hope this helps you
    • victorcas
      • Oct 2021
      • 12
      • España
      Thanks for replying!
      There are 3 capacitors around the circuit and all of them are 35V. The values are 10uF, 40uF, 220uF. I have checked them with a multimeter and they are all ok but I have replaced them anyway and it doesn't work.
      I have tested the power supply using a DC motor as a load but it doesn't work.... I will buy a car light to try it because I can't find a 12V resistive load that can handle a large amount of current. I have small bulbs that can draw around 80mA (I have also tested the PSU with one of these).
      The Impedance at the output is:
      12v - 60 Ohms
      3.3v - 94 Ohms
      5v - 42 Ohms
      5v VSB - 44 Ohms
      -12V - 570 Ohms
      I'm not familiar with the impedance values of an ATX power supply, but it doesn't seem to be shorted. right?
        • Jul 2011
        • 6070
        Do the power supply rails have a power resistors on them because your ohm reading are a little low
        • victorcas
          • Oct 2021
          • 12
          • España
          I have tested the PSU using a motherboard and it still does the same...
          Yes, it looks like it has SMD power resistors. I don't know their value because the "001" code doesn't seem to follow the standard (I'm confused). If I measure the resistance there, the multimeter shows 0.1 Ohms (the minimum resolution of my multimeter is 0.1 Ohms).
          There is also a through-hole resistor near the rails that is very odd... I haven't seen a resistor with 2 gold bands in the 3rd and 4th position (photo attached). The value read with the multimeter is 2.2 Ohms. I guess it is ok.
          I don't see any other power resistors near the rails.
            • Jul 2011
            • 6070
            Did you replace the capacitors around the power supply regulator ic chip you can not check with a ohm meter you need to check them with an ESR meter
            • victorcas
              • Oct 2021
              • 12
              • España
              After some tests the power supply stopped working definitely. I checked the board again and noticed that 3 resistors were broken (R62, R74, R25), so I replaced them with 4.7 Ohm resistors (I didn't have SMD resistors of that size).After that, when I plugged in the power supply and turned it on, I heard a clicking sound and nothing .... After that, when I plugged in the power supply and turned it on, I heard a clicking sound and nothing .... I have not heard that clicking sound again.
              I checked the diodes again but I don't see anything bad. I'm about to give up on this one.... I'm starting to think this PSU has more than one thing broken. I'm not sure if I broke something while checking it, but I don't think so.....
              Yes, I replaced the 3 capacitors (I used nichicon). I checked them with an ESR multimeter. I use the Amprobe AM-570 which can measure capacitance.
              PD: Sorry for the late reply. This is my hobby and I can only work on it during the weekend.
              • juergenb
                Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                by juergenb
                i am asking for some Help.
                I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                So i got a few of these from Banggood.
                I swapped the motor and now i have a new fault condition.
                In a working Frother you would press the start button, it will light red and work for a few minutes.
                If you press longer it will light blue and just mixup the milk.
                With the new Motor it just starts...
                03-23-2021, 11:24 AM
              • sbt123
                charnwood w821 mini wood lathe motor problem
                by sbt123
                hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                10-27-2024, 03:43 AM
              • d00m178
                Philips toothbrush 4100 (HX369BK) - motor getting hot
                by d00m178
                trying to fix Philips toothbrush 4100 (HX369BK)
                The battery started draining quickly.
                After disassembling it, I discovered that the motor gets very hot when brush is off, which is apparently causing the battery to lose charge.
                The motor is connected to contacts M1 and M2.
                When I turn on the brush, 0.4V appears on these contacts, and the motor starts running as expected.
                But when I turn off the brush, the voltage changes to 3.8V—exactly the same as the battery.
                The motor gets so hot you can't touch it. And after 5 minutes, the battery drains to 0V.
                (To...
                11-12-2025, 03:11 PM
              • mikey5791
                Help identify this motor
                by mikey5791
                Hi all forum members,
                Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                Correct me if i am wrong on the initial test.
                Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                11-24-2023, 07:54 PM
              • Per Hansson
                Motor run capacitor physical size vs voltage rating & measurements?
                by Per Hansson
                (TL;DR skip the first paragraph)
                I encountered my first dead motor run capacitor at a customer this week.
                For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                (Unless a servo motor makes more sense that is).
                But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                The pump would run but sometimes trip the 10A breaker.
                I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                Then it could...
                09-20-2020, 06:32 AM
