Voltage stabilizer trips RCD ?
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. A friend of mine asked me to have a look at this fat servo-driven voltage stabilizer. It claims to be 10kVa ! He says it works but it sometimes trips the breaker at the panel (not its own at the front there), despite having a very light load connected to it, or none at all. Unfortunately, I don't know for sure whether it's an RCD that trips here or a regular dumb MCB. Either of them could cause the issue if they weren't sized according and they'd get tripped by the high inrush current - this was my initial hunch, but the thing is he says it doesn't happen at startup, but rather during normal operation, more specifically when the mains spikes/sags and the stabilizer SHOULD do its thing, but instead all it does is pop the breaker. I haven't witnessed this myself and it's hard to replicate, so I don't know for sure.
    I plugged it in myself in a different location and sure enough it works as you'd expect: it fires up, the variac inside twitches a bit and you get 220v at the output, so the device itself works. What do you suppose could be causing this and what would a possible fix be, preferably still adhering to electrical safety rules ?
    Wattevah...
    • 31020
    Re: Voltage stabilizer trips RCD ?
    well........
    if you put 220v into a big inductor and then drop it to 190 the inductor charge will still be 220-ish.
    that alone is not going to please a lot of rcd's and such!
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Right - that's a big inductor after all. The current lags behind the voltage if I remember my basics. It'd be interesting to know if it's "residual current" part that trips because of an imbalance between L and N or the "overcurrent" part because of the current spike. The curve on the MCB/RCBO whatever it is is guaranteed to be C because that's the most common and it's extremely unlikely to see anything other than C around here for general purposes, unless it's a very specific and highly professional setup, which this ain't.....
      Wattevah...
        • 31020
        even the chinese battery-tab spot welders trip a C breaker
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          D-curve then ?
          Wattevah...
          • rddube
            Lenovo L490 Ram voltage circuit malfunction
            by rddube
            Hello friends,
            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
            07-15-2025, 04:41 PM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
            by sam_sam_sam
            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
            Now...
            06-09-2024, 10:57 AM
            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
            Based on Intersil's Robust Ripple Regulator...
            11-05-2024, 03:24 PM
