LiteON PA-2911-1-LF Blown Components
  • Kyleadonis
    • Oct 2020
    • 17
    • South Africa
    I opened up a Cisco network switch that no longer powers on and the power supply has three blown components:
    (See Photos Attached)
    -Power switch IC
    -Optocoupler
    -Resistor
    There are no blown fuses, mosfets, diodes. I know its impossible to ask what could cause this without physically looking at the board but does anybody know
    what could have caused these components to blow?
    Also finding a replacement power IC seems to be a bit of a mission as the top blew off and I cannot see the model of the IC. Can anyone help?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: LiteON PA-2911-1-LF Blown Components
    Hard to say exactly why that offline switch blew... but it's not uncommon.
    I see the PSU has really good input line filter, so I doubt a high voltage spike from lightning or similar could have done it... but still not impossible, I suppose.
    However, I do notice that this power supply appears to have an Active PFC circuit. Those are known for killing off-line switches and/or other primary-side components if the input capacitor(s) (in your case, the two big blue Hitachi HP3 450V 270 uF) have gone low in capacitance, high in ESR, or a combination of that... or open-circuit (APFC is well-known for murdering primary-side caps over time, too.)
    So perhaps start by removing the two blue caps and checking if they still show good ESR and capacitance.
    As for the bad off-line / power switch IC... I thought it might be a TOPSwitch IC, so I looked around at the various families. It appears that the TOPSwitch-HX family might be the one - i.e. TOP252, TOP253, TOP254.... and all the way to TOP262. See this datasheet:
    Then check the connections on your board.
    To me, it looks like you may have had a P or G package (see page 6 on the datasheet above, bottom left of the page.)
    The optocoupler is probably something similar to a PC817, but just in SMD version.
    As for the resistor... I can't quite tell from the pictures.
    But judging by the black spots on one corner of the bottom side of the PCB, I suspect you will find components related to the APFC circuit blown as well.
    Let us know what you find.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Actually, forget what I said above about the TOPSwitch. I think TinySwitch-III family might be what was used here, judging by the connection of the small SMD ceramic cap between pin 2 and primary-side ground (pins 5 thru 8). See this datasheet:
      So that blown switch IC is probably a TNY274, TNY275, TNY276... or TNY280. If you know how much output power the standby section has to provide, that should give you a good clue as to which one of these it is... or just go with a TNY280 and not worry, since that's the highest-rated one. All other parameters are pretty much the same for these TinySwitches.
      • Kyleadonis
        • Oct 2020
        • 17
        • South Africa
        Hi Momaka
        Thanks for your reply, I will definitely try those things you mentioned.
        I will keep you in the loop on the repair.
        • Kyleadonis
          • Oct 2020
          • 17
          • South Africa
          Okay so I am still busy with this power supply I've decided to go with the TNY208 IC. I tested the caps and did find some with a high ESR value. I also missed the one smd cap that's connects to the bypass pin on the power switch IC. The cap is definitely blown. I should be okay with a 100nF ceramic cap right?
          • Tomylee
            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
            by Tomylee
            Sorry for the person who’s going to read all this !
            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
            07-11-2025, 11:52 AM
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 05:30 AM
          • zlr8r
            HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
            by zlr8r
            Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
            To begin with, this laptop was dead-dead.
            Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
            • am getting white power led
            • 5-long-flashes on CAPS Lock and NUM lock
            • then, fan full speed
            • CPU heats up some (smaller die PCH, does not)
            • always constant black screen no matter what's tried
            • no USB recognition
            • no HDMI output
            this is as far as I can get with it and not sure where to inspect next ?
            I tried...
            03-27-2024, 03:13 PM
          • VitalComputing
            Chuwi HeroBox blown components
            by VitalComputing
            I have a Chuwi HerBox that has a number of blown components that I am having difficulty identifying. No schematic available.
            The fault is that the HDMI port does not really function properly, video looks shaky and has lines. The box boots fine on VGA, so I think the problem is isolated to the HDMI.
            The section below is the only section that seems to have damage to three components.
            1. Blue Arrow = I think this was a capacitor (as it is connected to ground) that blew clean off the board.
            2. White Arrow = I think this is...
            05-28-2023, 02:48 AM
