HP Z200 PSU Delta DPS-320KB-1 DEAD
  • Milio034
    • Sep 2021
    • 14
    • Netherlands
    Re: HP Z200 PSU Delta DPS-320KB-1 DEAD
    Visually it looked OK so I gave it a go. But now its not working as it should I will make it my next step. I don't have a cap meter so I hope the last electronic store in the surroundings can check it for me.
    Can components, like diodes or resistors that I find near the TNY become bad and lead to the described behaviour?
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Yes they can, I would monitor the 5VSB and see if it goes down when the computer turns off.
      So you know which part of the PSU it is that turns off, remember that the standby and main PSU are like two different power supplies.
      They do however depend on each other, well, the main usually depends on the standby that is.
      • Milio034
        • Sep 2021
        • 14
        • Netherlands
        I measured the pins on the 20 pin connector after taking it out of the PC. With the scheme of this custom build connector by HP I could find the 12V pins (gave a nice stable 12,12V and did not switch off) but I could not measure any 5V on the designated pin, was just 0,0V. A 3,3 line is not available in this connector. The 5V must have been working otherwise I could not have started up the system. Is there any explaination that the 5V was not up on the pin?
          MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
          This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-07-2024, 03:40 AM
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • Junkrepair
          Calculating ESR from tan delta -- tan delta's dependence on capacitance
          by Junkrepair
          I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
          I found this nice little description of the conversion:
          Calculating capacitor ESR from Tan(delta)
          https://forum.digikey.com/t/calculat...-from-tan/2633
          It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
          06-12-2023, 02:45 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
