Why does my Seasonic SSR-500GB3 whine??
  • Pimpom
    • Mar 2018
    • 9
    • India
    Re: Why does my Seasonic SSR-500GB3 whine??
    A stethoscope is great for locating the source of a noise. Even the cheapest ones will do. Just remove the chestpiece and point the open end of the tube around. I've been using the technique for 50+ years in my work.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Originally posted by shovenose
      Yes but I already attempted to warranty it and they said no. In the mean time I've voided the warranty by removing the cover and I've also swapped the fan with a different one because I wanted something with more airflow for a project.
      I'd replace the standby output caps with either FR or PW, using the biggest that physically fit. Eg- if it takes a D8mm, go for the tallest that fits, and of the highest value. Try for something like 2200u 6.3 or 10v. If it's got a pi filter, the first may be D10, the second D8.
      The tertiary aux supply, derived from the feedback winding, likely also supplies that PFC/PWM riser board. Tracing & proving this, to find other caps that need to be changed, is easier said than done. Black PCBs matter, lol...
      Originally posted by momaka
      The only two things I can think of to be causing that noise: either the 5VSB circuit (could be the transformer, or it could be from "sensitive" feedback loop on the 5VSB - though I suspect the latter does not apply, as that usually only happens when very low ESR caps are used on the 5VSB output filter)...
      The typical 431 feedback/opto arrangement sometimes has a small ceramic cap (Cff in example) from the cathode of the opto LED to the gate of the 431. If the first filter (C1 in example) is questionable, noise triggers the 431 via Cff & Rff (Rff is not always present) and the series ckt back to C1. At C2, things are calmer (after the pi section). "Feed forward" is attempting to dominate thru Cff & Rff while closer-to-DC feedback is taken after the pi-section; C1 no longer "dominates" and feedback/regulation hunts. This is usually low-frequency enough to be audible. The fact that the standby transformer is noisy in no way condemns it.
      Example:
      While the IC used in the above may be different, the feedback action remains the same.
      Shovey, try the following with the PSU removed or disconnected from the system in question. You'll be applying some loads to 5VSB.
      Note the noise with it unloaded. Now try either small light bulbs of increasing size (you can use 12v ones here) or various resistors. 18-20awg wire should work to probe the pins of the ATX connector.
      What you're looking, or listening , for is a change in that noise vs 5VSB load- I'd assume it'll be quite noticeable.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Example:
        Alright I am currently using it in a system but I'll be re-casing that system sometime next week as well as using a different PSU so I will try these things. We'll make it shut up somehow
        • Bitvive
          LG Flatron starts w. coil whine and power issues
          by Bitvive
          Hi ,
          My old LG Flatron recently started with coil beeping. This got worse every day for a few days until it also started having power problems.
          Now it also went off again after displaying the LG logo, then on, off again, then on and so on...
          So far I have measured the power supply unit, which delivers 19.21V and should therefore be OK. I removed the circuit board and connected it to the mains plug so that I could hear the coil beeping.
          During the beeping, I pressed on the coils with a non-conductive tool to see if the sound changed and to find...
          08-18-2024, 06:34 PM
        • 90Ninety
          Coil Whine , buzzing, identifying parts R9 Fury
          by 90Ninety
          I have an R9 Furty Nano ( R9 2XX IIRC ) that I want to put to use , I got it on ebay for quite cheap but, it has some of the worse coil whine I have heard .
          I tried putting a long tube on my ear and hovered it around the card while in use , I cannot pinpoint it . However I my educated guess is , that it the whine is an inductor coil and it is one or all of these in the picture . Does anyone know what part this is and what part I can replace them with .
          Perhaps likely is that I am missing something else it could be , here is a stock picture...
          12-15-2022, 04:18 AM
        • Uranium-235
          SMD coil whine "chirps"
          by Uranium-235
          Does anyone have high frequency sensitivity hearing and a motherboards have tons of sounds coming from it? Is this just coil whine en masse? When data to the SSD has high I/O I can hear the clicks and chirps. Same with when the graphics drive inits. Network adapters, chirping after I connect the cable
          I can hear everything. Every time I put my ear to let's say an open Shuttle XH series pc (currently working on) in the next room it sounds like I'm in the middle of a the fucking public bird aviary
          Of course this isn't just the shuttle, though I think the small case...
          07-10-2023, 10:06 PM
          by momaka
          03-12-2025, 03:42 PM
        • Jumme
          Boston Acoustics Soundware 5.1 SUB: Agonizing coil whine!
          by Jumme
          So. Had my Boston Acoustics subwoofer for 4 years and it had a terrible coil whine squeal from day one.
          I RMA'd it twice, but both times it came back (after a 6-8 weeks return time) and had the exact same problem.
          Said they "swapped the amplifier module". As it didnt help, personally I feel more convinced its the PSU module. Company now bankrupt and I cant stand the noise:
          Its a high pitch coil whine tone -it's terrible agonizing, when worst, I hear it clearly 4-5 m from the Sub (because sits in corner).
          It wines without RCA input....
          02-14-2021, 04:03 PM
