Sum-vision KY-550ATX inrush current limiter
  • Radio Fox
    • Jan 2010
    • 281
    My PSU "popped" a couple of days ago. Looks like the inrush current limiter has blown. Unfortunately the part of the component that came away has disappeared. It's the green component in the photo.
    Does anyone know the full markings for this component? I tried looking at a few websites with manufacturers logos on them, but couldn't find this one. The component still measures 6.6 Ohms in-circuit.
    The board is marked TB-1.2 REV:1.7
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
  • Toasty
    • Jul 2007
    • 4171
    Re: Sum-vision KY-550ATX inrush current limiter
    Find one from a junker PSU of equal or greater current rating (5A per the label). It's okay to put one from a 600w unit in there.
    veritas odium parit
    • seanc
      • Nov 2008
      • 1319
      I've used some of those (400w) in older PCs to extend their life just a bit more - they're pretty cheap and nasty on the outside, is the inside better?
      I'd pick up a better PSU if possible.
      • mur
        • 21
        This is a sunpro psu...
        I had a smiliar one (labeled 300w) which had this NTC labeled 8S050M.
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Wow look at the fuse on that thing!
          • seanc
            • Nov 2008
            • 1319
            I thought that too!
            • mur
              • 21
              Yep it's very definitely blown. You can see few burned resistors around 5vsb circuit and the big 5vsb transistor was shorted and the small 5vsb transistor blew itself in half. Oh and look at the bottom of c19 cap(5vsb filtering).
              • Radio Fox
                • Jan 2010
                • 281
                I have actually replaced the PSU, so there's no urgency to get this one going again. Other than the component thats blown, I don't think there is anything else wrong, as the PSU carried on working after the "pop", giving me time to shut the PC down normally. Although I haven't powered the PSU up again since.
                I don't have any suitable scrap units, apart from 2 (very) old PC's which probably only have 200/250W PSU's.
                Thanks for the photo mur. It gives me an idea of what I have.
                • Toasty
                  • Jul 2007
                  • 4171
                  >>Wow look at the fuse on that thing!<<
                  It's why ceramic fuses are a better (safer) choice.
                  @Radio Fox -
                  Mouser stocks a huge number of these in varying "flavors". (or is that "flavours"... )
                  http://mouser.com/Search/Refine.aspx...rd=ntc+limiter
                  Here's a link to Epcos' ICL's datasheet:
                  Toast
                  veritas odium parit
                  • Radio Fox
                    • Jan 2010
                    • 281
                    Thanks for the links Toasty.
                      master hoarder
                      • May 2008
                      • 12175
                      It does look like a Sun Pro as mur suggested. If it really is, don't bother! They use the cheapest caps possible, have tiny heatsinks and undersized components, and almost always a charred PCB as a consequence of that. Not worthwhile to fix in my opinion. Definitely something I'd never put in a working computer again.
                      But if you want to fix it for the sake of it, then why not. Keep in mind that the 450 watt rating on the label is a complete lie - this PSU won't do more than 200 watts, if even that much. With that said, a NTC from one of the old power supplies you have might work just fine.
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        Fox's psu isn't sunpro. Don't know what that is without a more detailed shot. Can't be too good, still has the 4 diode treatment.
                        Mur's psu is a sunpro, you can tell by the bright yellow transformer and just the text they use.
                          master hoarder
                          • May 2008
                          • 12175
                          I think it is. Model number on this one is KY-550ATX. If you look up Sun Pro on the UL site (E210743), their page has many other PSUs with this KY-xxxATX m/n format. And then there's the mismatched input diodes, which is something I've only observed in Sun Pro and Powmax/Leadman PSUs.
                          Well whatever it is, it's still a "HAZARDOUSAREA" .
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            I was thinking the same thing when I saw that pic.
                            Look at the remains of the glass is that all vaporized filament? Looks like someone tinned the glass envelope.
                            I think that's because the fuse was cheap Chinese crap I only buy and use fuses from Littelfuse and Bussman.
                            From 15 amps and up go Ceramic anything under that glass is fine.
                            • Radio Fox
                              • Jan 2010
                              • 281
                              On second thoughts, it's probably not worth the time & effort trying to repair. It did come out of a very cheap PC, so I'll just keep it for spares.
                              Thanks for all your suggestions.
                                • 31048
                                no, it's because it's just glass, bussman / littlefuse would do the same.
                                that's why you can get glass/sand filled fuses and like you noted, for safety situations there is glass / sand filled ceramic.
                                  Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                  I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                  I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                  I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                  02-04-2025, 08:08 PM
                                • Fritter
                                  Bulbs to avoid in current limiter
                                  by Fritter
                                  Just putting my first current limiter together (uk). Apart from led's, are there any bulbs that will not function as needed? Any advice much appreciated.
                                  10-31-2023, 11:24 AM
                                  Surface Mount Fuses Fundamentals Datasheet
                                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                  10-07-2024, 06:07 AM
                                  Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
                                  The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
                                  All AP21X2SG-13 AP21X2MPG-13 devices are available...
                                  10-23-2024, 03:33 AM
                                • DynaxSC
                                  Extreme High Current & Low Voltage Short Killer ??
                                  by DynaxSC
                                  Hi Folks
                                  I'm looking for a extreme high current short killer solution for a reasonable cost.
                                  I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                  After taking off the socket, the shorts dissappear again.
                                  The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                  10-15-2024, 10:13 AM
