80v charger blown caps .
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    ok i have an 80v charger here that came in not working . soon figured out the broken legs on the output diodes . must have been dropped to do that . i repaired that problem by soldering wires to the broke legs so as to reconnect them . all seemed fine so charger went back to owner . after 20 mins of charging there was a pop and smoke but charger still working . i have it open and found 2 series bypass caps blown to bits .these connect across the output caps . first off is what may have caused them blow and what to replace them with ?
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: 80v charger blown caps .
    forgot to say i have another of these chargers i can take apart to measure values on those caps but would be easier if someone can give me a ball park value to order .
      • 31084
      probably 100n 50v
      check the blue ceramics - top right in first pic.
      one has a mark
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        well spotted i missed that blue cap .tried to clean off the mark but its staying put so best replace it ..its marked 222 1kv . i expect its 2.2nf 1kv
          • 31084
          i'm sure a 2KV will fit
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            ordered 1kv ..i also took the good charger apart to have a nosy at the caps . 180nf but in circuit so wont be right . only measure one way so has to be wrong .
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              ok i have an 80v charger here that came in not working . soon figured out the broken legs on the output diodes . must have been dropped to do that .... after 20 mins of charging there was a pop and smoke but charger still working . i have it open and found 2 series bypass caps blown to bits .these connect across the output caps . first off is what may have caused them blow and what to replace them with ?
              Well, if that charger was indeed dropped a few times, those ceramic caps could have gotten cracked then and were just waiting for "the right moment" to short out and throw the sparks show.
              I fixed a surround sound system a while back that had a popped ceramic cap on one of the 35V rails after the owner moved from one house to another (which probably disturbed the unit/PCB enough to crack the caps.) After fixing this issue and the system working fine for a number of years... it did it again with another ceramic cap and once more when it was moved around. So either the PCB was flexing too much and breaking these or the caps were already with defects from the factory and just waiting for the right moment to go bad.
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                ok changed the caps including the blue one . did a good job considering the damage. one trace had to be glued back down .. charged a battery but it only took ten minutes . no smoke and nothing looking burned so its going back to the owner for more testing .
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  this thing is back again . different fault this time . the charger is saying bad battery pack but tried other chargers same packs and no problems ..am guessing its whatever makes the charger think the pack is bad . its generally too low pack voltage . tested all diodes and resoldered some iffy bits but still not working .. might start a new thread .
                    • Jul 2011
                    • 6040
                    Check the input voltage to the micro controller to make sure that it is correct voltage ( battery voltage ) especially sense you have one to compare to
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      not figured which pin on mcu just yet as need to remove lacquer of it and get the datasheet .
                      i have found though if i run it off about 100v mains it starts up and charges for a few minutes then knocks off with flashing red light to say bad battery pack .. but it only appears to be charging at about 79v .. this may or may not be a clue as to where to look next
                        • Jul 2011
                        • 6040
                        Actually it is a clue it might be something with the voltage divider circuit that goes to the micro controller or that part of the has an issue of some sort
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          ok have pic of the micro and 2 other chips just for fun ..
                          i cant find the datasheet yet
                          • petehall347
                            • Jan 2015
                            • 4427
                            • United Kingdom
                            well the bloody thing wont even try to start up today .. all i did was look for shorts and anything else obvious . there was a burning smell yesterday that i didn't find where it was coming from .i thought it was my dodgy electrics in the shed but maybe not .
                            there are a few pins on the mcu that seem to be shorted together ..i really need to pick up another charger to compare things with .
                            • petehall347
                              • Jan 2015
                              • 4427
                              • United Kingdom
                              it appears the mcu has managed to short out internally . have tried removing some ceramic caps thinking it might be one of those but no joy . the 5v feed to has 2 ohms to ground ..will remove the ic later to confirm .. am guessing the ic will have some custom firmware installed that i cant do much about even with a new one .
                              • petehall347
                                • Jan 2015
                                • 4427
                                • United Kingdom
                                ok its dead jim . will grab the other charger just to be 100 percent certain .
                                • odtech
                                  Asus UX490U laptop blown (caps?) on power board.
                                  by odtech
                                  Greetings friends.
                                  I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
                                  I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
                                  Any guidance...
                                  08-06-2023, 10:29 AM
                                • reessi
                                  20v / 2A SMPS for a Battery Charger - Explanation of Blown Resistors Please..
                                  by reessi
                                  My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
                                  The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
                                  The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
                                  I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively...
                                  08-22-2024, 08:12 AM
                                • motormayhem
                                  Lenovo T460 Only Charges on One Charger
                                  by motormayhem
                                  Laptop Question
                                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                  05-12-2023, 01:46 PM
                                • zlr8r
                                  HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                                  by zlr8r
                                  Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                                  To begin with, this laptop was dead-dead.
                                  Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                                  • am getting white power led
                                  • 5-long-flashes on CAPS Lock and NUM lock
                                  • then, fan full speed
                                  • CPU heats up some (smaller die PCH, does not)
                                  • always constant black screen no matter what's tried
                                  • no USB recognition
                                  • no HDMI output
                                  this is as far as I can get with it and not sure where to inspect next ?
                                  I tried...
                                  03-27-2024, 03:13 PM
                                • eryjus
                                  by eryjus
                                  05-10-2023, 11:21 AM
