Help identify there parts in Enermax EG365P-VE 5VSB circuit
  • POM_MJ
    • Aug 2009
    • 228
    I've got an Enermax EG365P-VE that had damaged in 5VSB circuit.
    1. 5VSB switcher mosfet was broken, can not read part number clearly.
    preced by K3, missing 2 number and last one is 7 (K3??7)
    2. two resistors was burned and a diode was broken, red circled them.
    Please help me identify there part.
    Thankyou in advance.
    POM
    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Help identify there parts in Enermax EG365P-VE 5VSB circuit
    You can start searching HERE . At most, 100 part numbers to check out (missing numbers from 00 to 99).
    Good luck!
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • POM_MJ
      • Aug 2009
      • 228
      HA HA! don't need to play lotto.
      I found the small missing piece of the mosfet drop on the floor, It is K3067.
      and from this thread by I4004 => https://www.badcaps.net/forum/showth...hlight=enermax
      5VSB pictures store on picasaweb => http://picasaweb.google.hr/i4004b3/E...55vStbySection
      R16 is 620ohm, another one is 39ohm
      Thanks to i4004
      from many schematic around here, the diode might be Zener diode 18V.
      • py924
        • Jun 2011
        POM
        Sir, Can you show me the value of resistance R10。THX。
        • py924
          • Jun 2011
          Good luck!
          • прямо
            Viper22A 5VSB circuit
            by прямо
            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
            01-13-2024, 07:05 PM
          • hobostove
            Corsair RM1000e - Help identify 5VSB Zener diode
            by hobostove
            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
            There's a 22ohm resistor that's melted and open, but it still has the bands.
            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
            It looks like the diode connects the source and drain of a TNY284...
            03-27-2025, 02:25 PM
          • edugimeno
            Help me identify the missing component... Sound to light circuit
            by edugimeno
            hI there!
            Im trying to help a friend repairing a large, real-sized short-circuit robot.
            This is remotely controlled and has a 2 way voice send/receive. Also while the hidden operator is talking, the red bulb inside the "mouth" should flash according to the sound
            Some other technician used to service it and he was fired leaving all the repairs unfinished and no documentation at all.
            What I found is a sound receiver, a speaker, and a wire directly to the mought bulb (a normal motorbike 5W 12V bulb).
            So I bought a simple 2X30W amplifier to feed the loudspeaker...
            02-14-2024, 10:23 AM
          • Alimash
            op amp circuit function?
            by Alimash
            I am repairing a ups which doesn't turn on ,it has the following ICs:
            SG3525 used to drive inverter mosfets.
            couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
            A LM358 and TL074 for control mechanism and of course the uController.
            The SG3525 is shutting down every time the ups is turned on.
            I want your help to know the function of LM358 and TL074 in the system.
            I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
            07-31-2025, 07:45 AM
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
