An old dinosaur bench top power supply - help needed
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: An old dinosaur bench top power supply - help needed
    Correct. This just means the in-out differential can be higher for the K versions but amps can't be that much higher - need beefier pass transistors to do this whether it be internal or external.
    • Kg74
      • Feb 2013
      • 67
      • Usa
      The power supply is from a company that is no longer in business. It was founded in 1983 so the unit is no older than 38 years. Like in the title - an old dinosaur. As the picture shows the design is simple and primitive. I must have bought in 20 years ago at a garage sale - never worked. Based on the posts it appears it is of a poor design heat sink wise.
      After looking up the price of a replacement 7805 and seeing how rickety the wires and pc board is I opted to go with the $9.00 eBay solution.
      I will update when the package comes from China and I get the unit working.
      Thanks all for the input - I appreciate the comments and learned a good deal.
        • Jul 2011
        • 6070
        Originally posted by stj
        https://www.cricklewoodelectronics.com/78P05.html
        i actually have 3a and 5a 7805's in one of my old parts drawers.
        dont ask how big the heatsinks were on them back in the mid 80's!!
        Thanks for posting this information I did not know there was this version of this type of regulator
        I have an application that I could use this type of regulator do you know if there is a 13.8 fix regulator in a 10 amp format
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          I still wonder who made that "78P05", and whether or not it's a fake ...
          Find datasheet? Never heard of "New Era Electronics" ...
          Don't think there's a 13.8V version, you'd probably can add a drop on the GND terminal on one of these if it really can handle 10A.
            • 31283
            when i worked in the arcade industry 7805's running 5a in a TO3 can where everywhere.
            heatsink like a shoebox!!!
            by around 86 switching psu's became cheap enough to replace them!
            • redwire
              • Dec 2010
              • 3912
              The original was LM309K 5V 1A competing with Fairchild uA7805K 5V 1A back in the day of 8080 home computers with TO-3. In the late 1970's the TO-220 package was good enough at those power levels and everything quickly went that way, much less hassle to assemble things. The LM323K was 5V 3A TO-3.
              OP could just keep the original PCB and wire up a LM317T. The sad thing is the new chinese kit will have crappier quality parts.
              It's a good basic linear PSU for experimenting and bench use. If the LM317 has the two protection diodes in the circuit, they last years. I would add a grounded power cord, ground the enclosure.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                I'm only thinking it was homemade because it seems poorly balanced, and I suspect the "indicator lamp" over the power switch looks like a hack job.
                Rectifiers are 1N4003 series 1A rectifiers... okay.
                2.5mF bulk capacitor... a bit oversized for 1A (funny looking, probably two series 25V 5mF capacitors heatshrinked into one?).
                little tiny heatsink... will go nuclear if outputting 5V@1A
                Lots of improvements possible...
                I have this homemade PSU that I picked up from the trash, it has a 26.8V 1A transformer, a bridge rectifier, an undersized but reasonable 500uF bulk filter capacitor, a LM317T, a meter, a DPDT switch to switch the meter between current and amperes mode, and misc "glue" components. This thing looks hideous and the LM317T is mounted on the only metal there is - the front panel. A chipset heatsink is attached via some pressure sensitive double sided tape, must be some huge thermal resistance between the LM317T and that heatsink...
                whether I should mod or redo this PSU I don't know, but people probably could say the same to my "real" homemade PSU... (CC/CV dual meter, 1.2V-14V, 0-2.5A, using LM317T and pass transistor, and yes I've fried that pass transistor multiple times also due to insufficient heat sinking...really insufficient...)
                • Kg74
                  • Feb 2013
                  • 67
                  • Usa
                  #28
                  Well the parts arrived from China and are now installed into the modified unit.
                  Attached are the photos - First is from the Top View displaying the incredible complexity of the modification. It was rather straight forward and I followed the advice given on how to keep the analog needle meter. I did pull the LED off the board and ran a jumper wire to the front panel.
                  The second photo shows the front view. It was just a matter of using a drill, Dremmel tool and file to make the modifications to the panel.
                  I agree the unit was some sort of kit/home brew as the PCB board has professional markings. Regardless I have an operational unit now and the cost was under $15.00 with shipping, including a spare module.
                  Thanks to all.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • shamsudeen
                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                    by shamsudeen
                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                    07-19-2025, 07:14 AM
                    03-31-2024, 02:12 PM
                  • rabsonnjala
                    LENOVO IDEAPAD 100 works only on bench power supply
                    by rabsonnjala
                    Hie I have a Lenovo laptop
                    Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                    it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                    below are my readings
                    with the original charger only
                    JBATT1
                    PIN1 0.22V
                    PIN2 0.22V
                    PIN3 0.45V
                    PIN4 0.45V
                    PIN5 O.43V
                    PIN6 0V
                    PIN7 GND
                    PIN8...
                    11-20-2021, 08:32 AM
                    07-01-2024, 06:34 AM
