Re: 1300W PSU - Help with replacement mosfet
Unfortunately that the only bulb i have in the house. its a new house to everything is LED.
I guess ill go out to lowes and pick up some high watt bulbs
Verified i have 3V on ps_on pinLeave a comment:
72w sounds like a halogen capsule hybrid.
it probably cant pass enough current for the pfc circuit to start - do you have anything big - like 150w?Leave a comment:
OK i did some testing with the supply switch on but pins not shorted.
my results are
150V across main filter caps.
150V on both source and gate on the two fets i replaced but nothing on the drain. I imaging the drain will only be present when PSU = on?
the two other fets i had highlighted in yellow in that picture:
Fet on right=
S & G = 150V
D= .45V or .55V depending on which side of main cap you use as ref
Fet on left:
S & G= .39V
D= 150V
Im not sure if these sound ok or not?
I'm not sure which part of the circuit switches it on i guess i can trace the psu -on pin and see where it goes....Leave a comment:
welp. i guess its a failure.
i get the 5vSB but psu doesnt turn on.
testing a spare 350W psu with the limiter i get all my voltages.
Do you think the 1300W is too much for the limiter or something?
im using a 72W bulb and bulb turns on and fades quickly when switching psu on.
Any thoughts?Leave a comment:
that lamp looks surprisingly white, is it a real glass filament lamp??Leave a comment:
Well parts came in. PSU is all back together!
i really wish i had a solder sucker! getting solder out of the holes with just solder wick can be a pain.
Anyways
I just need to find a bulb socket.
basically i took an old power cord. cut the end and attached it to a typical electrical socket and wall box.
I removed a foot or so of shielding from the cord exposing the wires.
cut the black one, and plan is to attach them to the bulb socket and bam.
Sound about right??Leave a comment:
Sounds like a plan.
Oh and when you get to the part with testing with the series incandescent bulb, you may have to try a few things there. Namely, since this PSU has APFC, the APFC circuit may not function properly with the series bulb.
Thus, my suggestion is to first start with a 60-100 Watt bulb and see if the 5VSB comes up and also if the bulb stays off (after turning on for a moment on two when the PSU is first plugged in.) If 5VSB comes up, you can try to tun on the PSU by connecting PS-ON on the 24-pin ATX connector to ground. If the incandescent bulb blinks on and off for more than 2-3 seconds, you may have to use a bigger bulb (or two or three more bulbs in parallel with the first bulb.) This will increase the power the PSU can draw through the bulb(s) and thus may now allow the APFC to function properly and make the PSU run. However, if the bulb(s) stay fully lit after trying to turn on the PSU, there may still be a fault in the PSU. Do report back if you run into either of these two cases.
The series bulb tester is a very useful tool, but can also sometimes get tricky to use on PSUs with APFC and may make you think the PSU still has a fault when it hasn't. But in any case, it is still a good idea to use it, as without it you do run the risk of blowing your new MOSFETs again.Leave a comment:
Thank you for your time and detailed explanation.
Ill order the stuff and see what happens.Leave a comment:
Despite its low resistance, a significant voltage rise can appear across that resistor when a very high current is passed through it momentarily, thus allowing ICs in the PSU to gauge how much current is passing through a given circuit.
These resistors are also typically metal-oxide flame-proof and fusible - that is, if overloaded severely, they will open like a fuse and will not burn down (something that regular carbon composition resistors may actually have trouble with.)
*EDIT*
According to the Digikey resistor calculator that Sam posted above, the resistors with color bands Black, Green, Silver, Gold, Green show up as 5.8 Ohms, 0.5%... and that's assuming the 3rd (middle) band is NOT actually Silver but rather Gray (calculator has no selection for Silver.)
And the other one (Blue, Green, Gray, Gold, Green) comes up as 65.8 Ohms.
Now that appears to be a match with your measurements in post #22, so I think they are OK indeed.Last edited by momaka; 03-14-2021, 12:39 AM.Leave a comment:
well why do they have 5 bands then? its confusing which is why i asked in the first place.
Whats the point in having such a low resistor there? does it act as a fuse?
If you did measure them as 4 band they would still measure lower then spec
which leads to ask do i replace them with 4 band spec or 5 band spec resistors?
https://www.digikey.com/en/resources...tor-color-code
Use the calculator for 5 and 6 band selection and you see what each band is forLeave a comment:
:/Leave a comment:
They are very low values, resistors very rarely go down in value. When I first looked up the values they came to 0.05Ω
Using the 4 band color code, they read 0.05Ω 5%Last edited by R_J; 03-13-2021, 03:11 PM.Leave a comment:
I guess im just looking for reassurance before i order. im just guessing on the 2 watts too does that sound about right?Leave a comment:
by DoOm86Hello.
I have a notebook with a shorted mosfet, it's a E6930 GA8125.
It seems to be a 30V dual asymmetric N-channel AlphaMos.
Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
And here is where I need help!
It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
Thanks!... -
by jm942Hi,
My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
I did voltage injection on the cpu with 0.7V and i have a current... -
by JaneI tried to use this method:
Testing an N-channel MOSFET:
Step 1: Discharge the Gate (turn off the MOSFET)
Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
Step 2: Charge the Gate (turn on the MOSFET)
Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM -
by String2016Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
by String2016i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
- Loading...
