Can someone please look at this photo and tell me how I would test the voltage of the 6 wires coming out of this ac transformer? Thanks!!
How to test ac transformer secondary output?
Tags: None
Re: How to test ac transformer secondary output?
The black should be the center tap of the purple and green wires, so you can check the voltage between the purple and green for the full secondary voltage or check between black and either purple or green.
I would need to see the bottom of the pc board to be sure that the black is the center tap. The other set of wires should be checked the same way (Red center tap?)
I said this before I saw the circuit board, so this is not correct in this case.
The Blue wire is the center tap and the Red and Brown feed the diodes.
The Black feeds a diode for a negative voltage so it is likely that either Green or Purple goes to ground and the other feeds another diode somewhere?Last edited by R_J; 01-01-2021, 07:13 PM. -
I would need to see the bottom of the pc board to be sure that the black is the center tap. The other set of wires should be checked the same way (Red center tap?)Comment
Looks like the Blue wire is the center tap and the Red and Brown feed the diodes.
What is it you are trying to do? just check if the transformer is working?Last edited by R_J; 01-01-2021, 07:16 PM.Comment
My main concern is damaging something by testing voltages between any of these 6 wires. Is that a concern? Thanks for the helpLast edited by JimBanville; 01-01-2021, 07:44 PM.Comment
Sorry. No disrespect intended, but I was getting such general/vague info. I'm competent enough to follow direct instructions, like "place dmm - lead at this point and dmm + lead at this point", but just telling me to check voltages leaves to much room for error. I deeply appreciate any help I can get!! Seriously.Comment
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by momakaFor today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
http://www.rmac.kingwin.com/products.../abt_650MM.asp
I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
What mostly drew me into buying it is its 2x PCI-E power connectors... -
by mikey5791Hi to all forum members,
This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
Fyi, i desoldered the secondary side electrolytic cap those over 1000uf... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by chth96Hello
I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor.... - Loading...
