Solytech with no 2 transistor 5vsb circuit?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    http://www.jonnyguru.com/modules.php...Story3&reid=65
    My rosewill 500W is similar to this unit, some subtle differences like OCP, 2 actual 12v rails, the resistor that committed suicide is not there (maybe a step up model, or solytech was aware of the exploding), and the 5vsb circuit is wayyyy different.
    On that, there is the usual 2 switching transistors on the main heatsink, and a transistor for the 5vsb circuit. Well on mine, it's not there. Instead, right where it would be, is a little 8 pin IC. A Infineon ICE3B0565 (http://www.datasheetcatalog.com/data...CE3B0565.shtml)
    So my question is, is this what is generating the 5vsb? A couple of the pins are connected to the standby transformer.
  • everell
    • Jan 2009
    • 1514
    Re: Solytech with no 2 transistor 5vsb circuit?
    Yes
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • i4004
      • Oct 2006
      • 2029
      surely, not the first time you see IC that steers +5vstby primary?
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Ok so this deer is definitely worth keeping.
        Same capacity on the secondary. 2 30A parts for 5v, 1 40A part for 12v, 1 30A part for 3.3v. Same 2SC3320 primary switchers. Massive secondary chokes, me thinks this is one that will actually put out it's rated wattage.
        Just recapped it
        12v
        16v, 2200uf YC TK -> 16v, 3300uf Samxon RS
        16v, 3300uf YC TK -> 16v, 3300uf Samxon RS
        5v
        10v, 3300uf YC TK X2 -> 10v, 3300uf Samxon RS X2
        3.3v
        5vsb
        2x 10v, 1000uf YC TK -> 2x 10v, 2200uf Rubycon MBZ
        • everell
          • Jan 2009
          • 1514
          Increasing the capacitance on the output capacitors for the +12v, +5v, and +3.3v rails I can understand because you see such a wide variation in loading from mother board to mother board. BUT, doubling the output capacitors on the 5vsb rail doesn't make much sense to me. I don't think there is such a wide variation in loading for the 5vsb circuit. Perhaps I am wrong. Maybe some of our engineering types could elaborate on this?????
          For a good working 5vsb I would think a PI filter with a pair of 1000 uF capacitors would be ideal. Doubling that capacitance would add a significant load on the 5vsb circuit. Perhaps I am overly cautious to make changes in component values of a properly working 5vsb circuit that uses a pwm chip.
          One thing to remember - the older ATX power supplies had a 5vsb rated for only ONE amp. Then the spec went up to TWO amps. The newer power supplies are rated for 2.5 amps. I don't believe OVERBUILDING this circuit is as important as the DESIGN of the circuit, especially moving from the two transistor design to the pwm chip design.
          • i4004
            • Oct 2006
            • 2029
            yes
            and he has put mbz, so he may have increased ripple on it...because originals probably didn't have such low esr....
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              They were the only 8mm caps I had and the old ones were bulged.
              I am going to replace them with correct 10v, 1000uf UCC's that I have, but I don't have access to them currently.
              • everell
                • Jan 2009
                • 1514
                I think making that change is a good idea. I seem to remember someone on this forum that changed capacitor values while working on a 5vsb pwm circuit. As I recall, it blew out the pwm chip. I don't remember where the thread is - or its name. Perhaps I will find it again some day.
                • i4004
                  • Oct 2006
                  • 2029
                  oh, you should have no trouble finding that lil gem toasty probably "induced" by suggesting "2x higher capacitance":
                  https://www.badcaps.net/forum/showth...KI50#post70064
                  surely the one to remember.
                  oh, another highlight from that thread, the "bonez' trafo":
                  https://www.badcaps.net/forum/showpo...8&postcount=16
                  umh...
                    • 31086
                    you need to treat the 5vsb like any other line,
                    in the past you didnt,
                    but a lot of motherboards now have jumper options to feed it to the ps2 & usb connectors for wakeup sensing etc.
                    if some dick has it configured that way and owns a usb scanner with no external psu or they connect a mobile-fone charglead or something then they are gonna hammer that circuit!
                    • everell
                      • Jan 2009
                      • 1514
                      Yes, that's the one. I think that post does merit some review because of discussion on:
                      1. 5vsb pwm circuit operation
                      2. Replacing parts with parts of significantly different value.
                      Due to the arguments involved, I suppose you could call that post as much a classic as the Kerri-Jane at the opera one. But lets not get the arguments going again. I think we all have plenty more to learn. So lets ditch the name-calling and arguments and think about how to EFFECTIVELY troubleshoot or modify the new generation of 5vsb circuits which have a pwm chip instead of the two transistor design.
                      As I reflect on it now, but did not suggest at the time - once the OKI50 chip was blown, he could have made a few circuit board cuts and added an outboard circuit using the DM311 as I have done many times, or even using another pwm chip. But all of the arguments - errors - and failures to mention - are now just history. So its time to move on.................
                      Happy New Year - 2010 - to all
                      • i4004
                        • Oct 2006
                        • 2029
                        well, not the post itself(which is just a report), but the complete thread.
                        only, opera is a matter of taste(and tastes differ) but troubleshooting techniques should be totally "tasteless", if you know what i mean.
                        offcourse, we don't know what really happened there(but overall i wouldn't suggest putting different values of components at all), one would need such psu to try few things....
                        i wanted to ask can you find such psu at your local bad psu supplier?
                        <wink>
                        • everell
                          • Jan 2009
                          • 1514
                          At my local bad psu supplier, I did find an Antec true power 550 eps. It had a two transistor 5vsb circuit using 4N60B and H945P transistors. I have never seen anything with the OKI50 smt chip.
                          Just before finding this forum, I purchased a NEW Antec Earthwatts EA430. It has a ICE2A0565Z pwm chip. This is the Infineon F2 series. The Solytech in this thread is using a later version Infineon F3 series, the ICE3B0565. Same family of chips, just later model. So the Solytech probably has a better chip. The data sheet for these chips looks real good. Guess I will have to get one to experiment with. Mouser has the F2 series available, but I didn't see anyone with the F3 chips available. I will have to keep things within the two dollar budget range!
                          Overall, I am pleased to see the trend of the newer power supplies going to the pwm chip. Much better.
                          • i4004
                            • Oct 2006
                            • 2029
                            yes indeed.
                            i presume dm311 fits that budget too?
                              • 31086
                              i read the datasheet for the dm311, but didnt see the maximum current it can pass,
                              is there a version in a decent package like a to220?
                              • everell
                                • Jan 2009
                                • 1514
                                All psu I have seen using the DM311 had the 8 pin DIP package and NO heat sink. My Antec earthwatts with the ICE2A0565Z is the 8 pin DIP package and NO heat sink. Photo of the OKI50 pwm chip was a small 6 pin surface mount package with NO heat sink. My conclusion is that these chips don't generate that much heat for the 2.5 amp max load in the 5vsb rail. The TO220 package used in most two transistor 5vsb designs I have seen were probably overbuilt - could produce far more power than needed - and when they failed put on a spectacular show..............bang, boom, and sometimes fire. The burn areas around the components in the old two transistor circuits is evidence that a lot of power was being wasted. When problem is encountered in pwm chip, it simply shuts down the circuit.......therefore no wasted power, and no excessive heat generated. Some heat sink would be nice - but is it really necessary?
                                • everell
                                  • Jan 2009
                                  • 1514
                                  370forlife - how about posting some pictures of your Solytech Rosewill 500 watt psu.
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    https://www.badcaps.net/forum/showpo...20&postcount=4
                                    I can take more pictures though
                                    • everell
                                      • Jan 2009
                                      • 1514
                                      Great - I would love to see what that 5vsb chip looks like in that psu. The chip number you gave (ICE3B0565) runs at frequency 100 Khz, whereas the DM311 I have been using runs at 67 Khz. The ICE2A0565Z in my Antec Earthwatts also runs at 67 Khz. I wonder why Solytech wants to run at the higher frequency???
                                      i4004 - cost for DM311 is $.87, cost for ICE2A0565 is $1.07 (prices from Mouser in USA). So both are within my budget. I was disappointed to see that the ICE3 series were not stocked by Mouser or Digikey. Data sheets show that DM311 was released in 2005, ICE series in 2004. So both are about the same vintage.
                                        • 31086
                                        higher frequency = smaller transformer.
                                        also needs better inductors & caps though - so not a big cost saving.
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • Tarot Superstars
                                          Short Circuit tester
                                          by Tarot Superstars
                                          Hello.
                                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                          Link
                                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                          https://www.youtube.com/watch?v=0eixDdCpiO4
                                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                          09-25-2023, 09:11 AM
                                        • Alimash
                                          op amp circuit function?
                                          by Alimash
                                          I am repairing a ups which doesn't turn on ,it has the following ICs:
                                          SG3525 used to drive inverter mosfets.
                                          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                          A LM358 and TL074 for control mechanism and of course the uController.
                                          The SG3525 is shutting down every time the ups is turned on.
                                          I want your help to know the function of LM358 and TL074 in the system.
                                          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                          07-31-2025, 07:45 AM
                                        • M1NEBLANK SHOW
                                          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                                          by M1NEBLANK SHOW
                                          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                                          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                                          Schematic and Boardview here
                                          04-04-2025, 03:57 PM
