Solytech with no 2 transistor 5vsb circuit?
  • i4004
    • Oct 2006
    • 2029
    Re: Solytech with no 2 transistor 5vsb circuit?
    >higher frequency = smaller transformer.
    should be...but in the pics 370 posted +5vstby trafo actually looks a bit bigger than average....then again it's still rosewill..heh
    >The ICE2A0565Z in my Antec Earthwatts also runs at 67 Khz. I wonder why Solytech wants to run at the higher frequency???
    i would say trend (in the indistry) is probably to use higher and higher freq. as probably efficiency rises with the freq.(the stuff stj said about size).
    as for does it REALLY gain anything, no, i wouldn't say so...i would say 67khz is perfectly fine....overall i would like to see this freq. go down, not up (that would mean less strain to components), but that would mean bigger trafos, yes...
    i would actually go to the extreme(like i mentioned some time ago) and make +5vstby a linear supply. that would surely outlast any smps design. stress is practically non-existant with linear supplies. 1A design would probably suffice(as who actually utilises full 2A from +5vstby?).
      • 31247
      the biggest thing is that once the frequency goes over a specific threshhold (no, i dont know what it is),
      you can switch from big iron/steel core transformers to compact ferrite ones.
      • прямо
        Viper22A 5VSB circuit
        by прямо
        So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
        In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
        01-13-2024, 07:05 PM
      • Astonished
        Fixing the Charge Circuit of the Batteries of the DC Motor
        by Astonished
        Hi friends of electronics
        What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
        The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
        Please help me fix this circuit.
        (the datasheet of the IC: https://pdf.datasheet.live/28...
        01-28-2025, 06:24 AM
      • Tarot Superstars
        Short Circuit tester
        by Tarot Superstars
        Hello.
        I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
        The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
        Link
        The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
        https://www.youtube.com/watch?v=0eixDdCpiO4
        My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
        09-25-2023, 09:11 AM
      • Alimash
        op amp circuit function?
        by Alimash
        I am repairing a ups which doesn't turn on ,it has the following ICs:
        SG3525 used to drive inverter mosfets.
        couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
        A LM358 and TL074 for control mechanism and of course the uController.
        The SG3525 is shutting down every time the ups is turned on.
        I want your help to know the function of LM358 and TL074 in the system.
        I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
        07-31-2025, 07:45 AM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
