help please - antec trouble!(not caps)
    • 31025
    hello.
    i'v been reading here for months, but just registered by need!
    i'v got a couple of psu's i'm repairing that are trouble.
    1: Antec smartpower sp-500p
    PFC fet shorted and desroyed the pfc choke!!!
    anybody know the current and henry rating?
    or have a spare?
    also the soldering is the worst i'v seen in years!
    so bad that a resistor is missing!
    on the low-voltage side in one corner are 4 chip components in a line.
    1 cap & 3 resistors.
    the endmost resistor is prefixed "R63a" and *missing*
    anybody know the value of it?
    these smartpower crap use sleeve-bearing fan's btw!
    the other psu is a Thermaltake pure-power 480APD
    there is a small upside-down board over one side that has carbonised a resistor, a diode and a chunk of the board.
    i'll need to foto this, does anybody have any experience with this psu model?
    merry x-mas btw.
  • Toasty
    • Jul 2007
    • 4171
    Re: help please - antec trouble!(not caps)
    re: SP-500P -
    Does R63A have a red dot of glue? Flat or pointy? Very odd for one to -fall- off.
    Best bet is to get a dead one and swap parts. The shorted FET may be the result of a failed mains filter cap or other component. Odd the fuse didn't catch this.
    Pics please.
    veritas odium parit
      • 31025
      it took the fuse to hell with it.
      R63a was there, the glue is missing and took a patch of the green laquer with it - also i can clearly see the rectangle imprints in the solder.
      maybe the guy i got it from caught it on a screw-post taking it apart for a look.
      getting a dead one - i did - this is it.
      no chance of seeing another - nobody i know buy's antec anymore thanks to a combination of this forum and the price.
      Btw, how good are superflower? i know a few people with them who have run them fine for several years.
      • Toasty
        • Jul 2007
        • 4171
        I meant a dead one from Craig's list or Ebay or a swap meet.
        Put it up in the -wanted- thread. Maybe a member has one sitting in the junk shelf.
        What are the numbers on R62 & R63? I have a SP-450 here that matches your layout. Understand that these are factory applied variable values that are used to set voltage or current. 2 resistors in parallel to "trim" a particular setting. Cheaper than trimpots.
        Pics
        veritas odium parit
          • 31025
          i'l open it again - maybe a nice cermet-trimmer would be a worthwhile upgrade.
          i de-wound the inductor now - 73turns of 1mm copper.
          and sanded the burned paint & laq off of the ferrite ring - so i'll re-wind it.
          that just leaves this damned resistor.
          • Toasty
            • Jul 2007
            • 4171
            Adventurous soul, aren't we?
            If that core is indeed ferrite (how do you know), and it has been substantially overheated, the magnetic permeability (Mµ) will have been affected. That means no matter what you do in rewinding, the end result will not be correct. If it was a minor overheat and just crisped the wiring, you may be okay. If it's a powdered iron core, you're okay as they are not generally affected by overheating.
            Trimmer does no good as it's not an adjustment that needs to be made. It is factory set and should be left alone.
            >>that just leaves this damned resistor.<<
            ...and the MOSFET, and input cap, and relubing the fan, and......
            All this for a $35 PSU.............?
            Toast
            veritas odium parit
              • 31025
              not $35 in Europe i can tell you - more like €50+
              the inductor had got so hot that the laq had turned black and fused to the core instead of the wire.
              i can easily get another core from some junk.
              the resistors are:
              r64 = 2k
              r63 = 12k
                • 31025
                oh yea, i already binned the filter caps - they were branded "fukyu"
                • Toasty
                  • Jul 2007
                  • 4171
                  R63A = 10kΩ
                  The 3 resistors and the cap are in parallel across the base lead of the H945 transistor (right next R63A) to ground. Their measured value on my 450 is 1.44kΩ. The -calculated- value is 1.463kΩ.
                  The transistor emitter feeds the 3.3v OV/UV signal through the zener diode ZD2 to pin 5 of the TPS3510 supervisor IC.
                  You are sure the coil is the PFC coil, correct?
                  Check the diodes around that coil and FET(s) too. One (I think) is mounted on the heatsink.
                  Toast
                  veritas odium parit
                  • Toasty
                    • Jul 2007
                    • 4171
                    Pics of the area:
                    veritas odium parit
                      • 31025
                      that's exactly what i needed! thanks.
                      and an easy value to scavenge too!
                      yes, the pfc coil and the pfc fet on the end of the heatsink IRFC460A
                      i'v already pulled them and all the electrolytics off.
                      i'm making a list to recap an sp, a tp2 and a couple of fps's at the same time.
                      then i'm going to look at my ac-bel i pulled from a powermac-G3 & converted to atx.
                      that's running my athlon used to post this msg till i sort the fsp's, it runs fine but it's had a hard life so i dont want to push my luck with it.
                        • 31025
                        already checked the pfc diodes btw, they look fine when cold.
                        i'm more concerned about the i.c. that drives the fet - the fet was shorted pin2pin.
                        • jinu_j
                          by jinu_j
                          Hi
                          05-03-2025, 10:51 PM
                        • mikey5791
                          Need help to replace burned resistor in 350w atx psu
                          by mikey5791
                          Hi to all forum members,
                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                          12-26-2024, 04:55 AM
                        • MidnightRoller
                          Can a resistor lose resistance after hot air?
                          by MidnightRoller
                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                          02-02-2022, 11:46 PM
                        • artvandalai
                          What resistor ohm will work better to repair this waterpik?
                          by artvandalai
                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                          01-05-2025, 04:10 PM
                        • chth96
                          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                          by chth96
                          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                          Since then, This AC/DC adaptor have been out of order.
                          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                          And Is there any possibility that it will suddenly explode as well as to be out...
                          12-03-2023, 04:40 AM
