Bad ripple on -12 V rail of recapped Macase MG-300EP: should I worry?
  • tj2
    • Oct 2009
    • 85
    This week I replaced all the Fuhjyyu capacitors in my Macase MG-300EP 300 W AT style PSU. The operation apparently was a success, though today I got curious and put the PSU on the scope to look at ripple. All rails are in spec on the voltage and +5 and +12 had reasonably low ripple. However, the -5 V rail has a bit more than 1% ripple and the -12 V rail has terrible ripple: more than 3%. Here are my results
    Code:
     Nominal Actual  Ripple (p-p)
      +5 V +5.19 V  15 mV
     +12 V +12.00 V  65 mV
      -5 V -4.87 V  60 mV
     -12 V -11.53 V  400 mV
    I've read that few devices use -12 V, and though my components are all from the 1995 or newer, I'm still worried. Now I'm going to check the individual PCI and ISA cards for connections to -12 V. (On PCI -12 V is the first pin on the component side and on ISA it's the 7th pin in the solder side. Pins are counted from the back of the computer.) I didn't write it down, but I recall that the spikes come every 17 ms or so, corresponding to 60 Hz. Now I'm kicking myself for not measuring the ripple BEFORE the recap. I decided to recap because the PSU is from 1996 (and still in use) and all the caps were Fuhjyyu.
    So, is there reason to worry?
  • linuxguru
    • Apr 2005
    • 1564
    Re: Bad ripple on -12 V rail of recapped Macase MG-300EP: should I worry?
    The -12v rail rarely has any load on any modern PC - it's only used on serial cards that exactly implement the original RS-232C electrical specs (like ISA cards on the original PC/XT and AT) and occasionally by soundcards that have an onboard chipamp (relatively rare today, and they generally use only the +12v supply).
    In both cases, the 400 mV ripple is largely irrelevant.
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
      by momaka
      03-15-2023, 10:17 PM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • lefetylorant
      Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
      by lefetylorant
      Hello Everyone,
      Long story short, I got this unit for very cheap.
      I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
      I've performed some measurements:
      - 20V rail perfectly...
      09-14-2023, 05:05 AM
    • bimole
      Weird behavior on 3.3V rail of a CORSAIR CX600
      by bimole
      A colleague gave me an apparently ill CORSAIR CX600.
      He told me that he heard a banging noise, and smelt the magic smoke.
      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
      It's another story on the 3.3V rail...
      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
      02-13-2025, 04:49 AM
