Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Adding polys to power supply
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    I was just pondering (zoiks, narf,) about this. Say if you had a power supply that had two 3300uf, 10v caps filtering the 5v rail. Could you do something like take out both caps and put in one 5600uf, 10v cap with something like a 820uf or 560uf, 16v poly?
    Would there be any benefits, would the solid help reduce ripple? Of coarse price would be pretty high, a 5600uf 10v nichicon HE is about $1.40 and a 16v, 330uf oscon is $.43, where as 2 3300uf 10v samxon's are $1.01 each. Cost would actually be less
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Adding polys to power supply
    hmm... seems like overkill to me. not unless you are talking gutless wonder with few filter caps. then it might be worthwhile...
    sigpic
    (Insert witty quote here)
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      http://search.digikey.com/scripts/Dk...me=493-3115-ND
      If I was going to get poly's for one to do this, I would probably get these. Cost just skyrocketed.
      http://search.digikey.com/scripts/Dk...me=493-3112-ND
      oooo, 1200uf for the 10v. That might be a little more feasible.
      • Toasty
        • Jul 2007
        • 4171
        See PCBONEZ's post in the Nichicon HN HM thread:
        Post #29
        https://www.badcaps.net/forum/showth...?t=8454&page=2
        Toast
        veritas odium parit
        • i4004
          • Oct 2006
          • 2029
          nobody can really answer that prior to testing it first.
          except perhaps somebody that actually designs these PI filters and knows his job.
          he, then, perhaps would say "ripple goes somewhere eventually, and with lower esr more ripple goes to ground, and that means you have more ripple on the output, as ground is the same for psu and mobo".
          <wink>
          in other words what if that esr actually "sponges" some of the ripple(converts it into heat, just like normal resistor would?), and deacresing it brings ripple up...
          offcourse too much esr has effect of diverting most ripple to output...and capacitance goes down when esr goes up, so cap is really not doing much of stuff it should.
          (in that aspect it's amazing how totally blown caps with esr of 20 and more still work in psu....psu shuts off only when things go extremely bad....to that extent you don't need to think about extra good caps there, just put "good" caps and it'll probably extend life of psu to more than you'll use it...ie other components of the pc will be outdated by then)
          oh yeah, toasty, you can link particular posts.....that "#29" is actually a link too..ie
          https://www.badcaps.net/forum/showpo...0&postcount=29
          • yanz
            • Nov 2004
            • 910
            i've been thinking about that for long.. good that you mentioned it.. though not much of answer..
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
              03-31-2024, 02:12 PM
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
